Gen 4 Front Grille Removal
01 Feb 2020 12:43 - 01 Feb 2020 12:48 #217923
by 1tamad
Replied by 1tamad on topic Gen 4 Front Grille Removal
Do you have better pictures on the location of the push rivets and lower clips?
Where do I start to pry the grill off. I'm afraid to break it.
Thanks.
Thanks.
Last edit: 01 Feb 2020 12:48 by 1tamad.
- Thank you received: 622
01 Feb 2020 17:03 #217931
Replied by Soeley on topic Gen 4 Front Grille Removal
Photobucket is rubbish for blurring out pictures now I have reached my limit
Here they are hosted by Imagur.
01 Feb 2020 18:38 #217936
by 1tamad
Thank you very much.
01 Feb 2020 18:47 #217937
I should have added. with the bottom clips just insert a screwdriver and turn 90 degrees, the bottom of the grille will pull away. When refitting and it is pushed into place turn 90 degrees again to lock into place.
- Grim Reaper
- Senior Member
- Thank you received: 10
07 Jul 2020 10:10 #224636
by Grim Reaper
Replied by Grim Reaper on topic Gen 4 Front Grille Removal
The part number for the bottom clips is 72115-78R00
For when you break them because you didn't know they were quarter turn and you couldn't work out how they released
- Matt5141
05 Nov 2020 08:37 #229696
by Matt5141
Replied by Matt5141 on topic Gen 4 Front Grille Removal
I've undone the push rivets and lower slot release but struggling from there. Do I need to undo all the trim clips before pulling the grille off as I can't really get to them and feel like ill break the grille if I pull beforehand
Time to create page: 0.189 seconds
