Gen 4 Front Grille Removal
- Thank you received: 622
22 Feb 2019 15:07 #203682
Gen 4 Front Grille Removal was created by Soeley
Does anyone know how to remove the front grille? Found a few catches and fasteners but it's still held tight.
22 Feb 2019 16:32 - 22 Feb 2019 18:53 #203691
Replied by Soeley on topic Gen 4 Front Grille Removal
Easy when you know how!
From under the bonnet remove two plastic push rivets. Then at the bottom of the grille in the lower horizontal slot release two clips. Once those are done there is just a series of trim clips around the indicator area and along the top edge. Just pull firmly.
A big thank you to Darren at KAP for letting me disturb him while he was in the spray booth
NOTE: Photobucket back up so pictures added.
Last edit: 22 Feb 2019 18:53 by Soeley.
- X8GGY
22 Feb 2019 17:07 #203693
Replied by X8GGY on topic Gen 4 Front Grille Removal
You can't tease us with half a story?!
WHY are you taking the grill out? (on a brand new car?!)
22 Feb 2019 19:07 #203700
I'm replacing the horn.
I have a Stebel Nautilus compact Air Horn. I had it fitted to my previous car ans it has to go on the Jimny. I was hoping it would fit where the std horn is, but it's a bit tight, but I have a plan :whistle:
- Thank you received: 1992
22 Feb 2019 19:50 #203702
Replied by Lambert on topic Gen 4 Front Grille Removal
Swapping it for a train horn?
22 Feb 2019 20:07 #203704
Haha, not quite but nearly.
Time to create page: 0.169 seconds
