Alternative Antenna
- Thank you received: 591
21 Jan 2019 20:05 #201380
Replied by Soeley on topic Alternative Antenna
I did look at one of those DAB windscreen antennas thinking it might improve the signal for me.The lad I lift share with has a Merc and his DAB goes off in certain areas for only a very short period. Where as mine is going off for much longer periods in more places that his, so I doubt that is signal related, must be antenna receiver related.
But first things first, I will check out the wires/connections at the base of my antenna.
- Max Headroom
- Banned
- Thank you received: 217
21 Jan 2019 20:07 #201381
by Max Headroom
Replied by Max Headroom on topic Alternative Antenna
We are in the Cotswold hills here so there will be DAB black-spots in places - but even so its not that much
23 Jan 2019 06:19 #201474
Replied by yakuza on topic Alternative Antenna
I live in a geologically challenged country, in between hills and valleys and i changed my glass antenna to a cheap ebay DAB/FM active antenna for the roof. Placed it center and 15cm from the back edge of the roof. Acc to an antenna specialist there should be 15cm of steel around it minimum.
Works great.
Works great.
26 Jan 2019 12:09 #201739
Got some pictures of the underside of the antenna base, not brilliant as it was difficult to get the camera between the roof and headlining.
Looks like three wires on one connector, an aftermarket replacement might be a problem unless the new wires are run to the head unit?
Not sure how the surround comes off the screen to try and get a look at the connectors at the back of the head unit?
- TaterTot
26 Jan 2019 14:45 #201747
by TaterTot
Replied by TaterTot on topic Alternative Antenna
Is it 3 wires from the antenna base, to the white connector there? I can't really imagine anything else.
26 Jan 2019 17:08 #201759
Yes exactly that, shadow from the flash makes it look like more wires.
TaterTot wrote: Is it 3 wires from the antenna base, to the white connector there? I can't really imagine anything else.
Time to create page: 0.224 seconds
