Alternative Antenna
- TaterTot
Soeley wrote: The whip is 12" over all and 6" too long to pass under the door. tried to get some silicone grease today but failed, will have a look online.
Oh. I was hoping it wasn't that much. That's too much to just bend it. Amazon has a bunch of Stubby antennas for FM. Pick one that is 1/2 the length of the antenna (but will still fit). If non are close, pick one that is 1/4.
- TaterTot
The grease isn't for lubrication. It's to make sure nothing can ever get in.
TaterTot wrote: Yes, it is "multi-band", just as an antenna on a regular VHF-hand radio is. Most of them are VHF and UHF. It's just it's length that decides which frequencies it works with.
I doubt if its the same as a standard VHF radio. If you check under the headlining you will probably fine two connectors, a standard ISO radio connector for the FM antenna and a Fakra/SMB connector for the DAB. On some the power is sent up the same cable but you may find a separate supply because of the GPS.
Something like this one.
Look carefully at your antenna and you will see the second, longer antenna wrapped around the shorter inner antenna.
- TaterTot
You talking about the "foot" itself now?
- Thank you received: 583
I did buy a short replacement from Halfords today, Turned out it was still an inch too long, but I did notice that the FM reception was worse, so that is back in the box to be returned.
I really appreciate all your help and am taking all your comments on board.
