Alternative Antenna
- Thank you received: 632
18 Jan 2019 20:35 #201089
Alternative Antenna was created by Soeley
I have found one slight problem with my Gen 4 Jimny so far. Although in the garage there is plenty of height, I even measured the height under the Up & Over door when open, the roof clears it fine but the aerial is another matter. Due to the aerial not being that flexible i'm having to unscrew it every time I park in the garage, and then replace on leaving.
I'm sure I'd seen some pictures previously that looked like the aerial had a pivot at the base so it could be folded flat. Does anyone know of a specific Suzuki that has one like that I could use? I have been told today that the base will hold the GPS antenna and the actual aerial is for both DAB & FM so a replacement would need to satisfy all 3. I was kind of hoping I could swap it for a whip aerial that could be clipped to the front gutter for entering the garage.
Any suggestions welcome.
- TaterTot
18 Jan 2019 21:08 #201091
by TaterTot
Replied by TaterTot on topic Alternative Antenna
Is it possible to unscrew the whip that is there today, from the socket? I doubt that the GPS uses the whip, as the frequency for GPS does not match that antenna.
Or a close up picture would help.
18 Jan 2019 21:31 #201093
Replied by Soeley on topic Alternative Antenna
I'll take one tomorrow, cheers.
19 Jan 2019 17:22 #201155
Ok, this is the base with the whip removed, it does look like there is a mark where another version could possibly have a slot to allow for the whip to be swiveled down. The thread is 3/16" BSF.
And with the whip attached.
I have come up with a temporary solution. Some stiff garden wire bent to hook under the gutter and hod the whip down.
TaterTot wrote: Is it possible to unscrew the whip that is there today, from the socket? I doubt that the GPS uses the whip, as the frequency for GPS does not match that antenna.
- TaterTot
19 Jan 2019 17:49 #201158
by TaterTot
That there looks to be a stock antenna. One solution is to get an antenna swivel, and lay it flat(ter). Another is to get an antenna that is shorter (I'll have to calculate this one to be sure, but 1/2 length should be ok). Shorter antenna means not as good signal. No matter how flexible it is, repeated bending because a clearance issue, will cause damage.
I can't seem to find pre-made angled joints for that antenna, sadly.
Also, since you have already unscrewed it. I would suggest you get some contact Vaseline, so moisture can't get in there.
How much too long is the antenna?
- TaterTot
19 Jan 2019 18:00 #201160
by TaterTot
Maybe you could actually use a shark fin kit. Looks like those would fit over the "foot" you have. Only issue I see, is that the Jimny roof doesn't look flat around the antenna foot
Time to create page: 0.195 seconds
