Bump stops
- TomDK
S200KYS wrote: Depends on what you're trying to achieve?
We fit bump stops for a number of reasons -
1) If the compressed length of your shocks would mean they were "topping out" (the piston fully closing an hitting the top of the shock) before your suspension hit the bump stops, this would clearly damage the shocks, so fitting bump stop extensions would make the suspension top out before the shocks do.
2) To stop the springs going "coil bound" (all the spring coils compress so much that they touch each other), this can lead to spring fatigue which will make the springs sag over time...
3) Fitting bigger tyres that would hit the arches (or bumpers in my case, that's why I'm fitting mine soon) before the suspension tops out... So the axle hits the (extended) bump stop before the tyres hit the arches...
4) To aid suspension flex / articulation, when one side of the axle hits the bump stop, the other side naturally hangs down more due to the leverage effect...
So, it depends on what you're trying to achieve... my 4" - 5" lift worked fine with the 235/75/15s on, but now with 31"s on the tyres hit the bumpers, so I'm going to increase my rear bumps from 1.5" to 3" and the front to match, this will stop the tyres touching, as they used to tuck into the arches behind the bumpers -
Protecting the shock from topping/bottoming out is the sole purpose of the bump stop.
The boxed length of a springs is much shorter than the compressed length of a shock. So if spring length match the shock length, then 2) will never be an issue.
I see very little point in 3). Of course we don't need to agree. But why fit so big tyres that they rub the bumper. And then install bump stops to limit the suspensions up-travel?
Making bump stops longer to force down travel of opposite tyre is just wrong.. It may be a side effect of using bump stops. But not something you should put into considering when looking for more articulation.
Easiest way of figuring out length of bump stop is to remove springs. Jack either end of Jimny up on stands and then use a jack to lift the axle up only the shock is fully compressed. Then is a matter of measuring how much longer the bump stop needs to be.
- X8GGY
- TomDK
- TomDK
Daniel30 wrote: Not if your new to the 4x4 scene and by your response after I've measured it are you saying it will be 3inches then??
Depends what 3" lift you get. But you're probably getting a Jimnybits lift?
But yes... Best is to measure it. No matter what.
