Bump stops
  • Daniel30
04 Dec 2015 10:52 #157829 by Daniel30
Bump stops was created by Daniel30
What size bump stops do I need for 3" lift?
Cheers
  • TomDK
04 Dec 2015 11:40 #157832 by TomDK
Replied by TomDK on topic Bump stops
Daniel30 wrote: What size bump stops do I need for 3" lift?
Cheers
Isn't that pretty obvious? ;) :P
  • X8GGY
04 Dec 2015 11:43 #157833 by X8GGY
Replied by X8GGY on topic Bump stops
Depends on what you're trying to achieve?
We fit bump stops for a number of reasons -
1) If the compressed length of your shocks would mean they were "topping out" (the piston fully closing an hitting the top of the shock) before your suspension hit the bump stops, this would clearly damage the shocks, so fitting bump stop extensions would make the suspension top out before the shocks do.
2) To stop the springs going "coil bound" (all the spring coils compress so much that they touch each other), this can lead to spring fatigue which will make the springs sag over time...
3) Fitting bigger tyres that would hit the arches (or bumpers in my case, that's why I'm fitting mine soon) before the suspension tops out... So the axle hits the (extended) bump stop before the tyres hit the arches...
4) To aid suspension flex / articulation, when one side of the axle hits the bump stop, the other side naturally hangs down more due to the leverage effect...
So, it depends on what you're trying to achieve... my 4" - 5" lift worked fine with the 235/75/15s on, but now with 31"s on the tyres hit the bumpers, so I'm going to increase my rear bumps from 1.5" to 3" and the front to match, this will stop the tyres touching, as they used to tuck into the arches behind the bumpers -
  • X8GGY
04 Dec 2015 11:44 #157834 by X8GGY
Cheers
No :P , see reasoned answer above ;)
  • Daniel30
04 Dec 2015 12:48 #157841 by Daniel30
Replied by Daniel30 on topic Bump stops
Thanks DAVE!!!!! :laugh:
I'll have to work out what tyres I'm going to end up with and go from there
Cheers
  • X8GGY
04 Dec 2015 13:08 #157842 by X8GGY
Daniel30 wrote: Thanks DAVE!!!!! :laugh:
Cheers
No problem Dan' B)
Time to create page: 0.089 seconds
