Bump stops
- TomDK
04 Dec 2015 18:42 #157861
by TomDK
NICE.. Excellent choice of suspension
With that 3" suspension lift from Trail Master you should know that the springs are in fact of the same length as the 2" lift. The extra inch of lift is gained by a higher spring rate
So you definitely need to measure, just to be sure.
Replied by TomDK on topic Bump stops
04 Dec 2015 18:45 #157862
Replied by Daniel30 on topic Bump stops
Ok cheers TomDK
- X8GGY
04 Dec 2015 19:23 #157865
Replied by X8GGY on topic Bump stops
That's better, friendly informative responses... :woohoo: :evil: :whistle:
04 Dec 2015 21:05 - 04 Dec 2015 21:07 #157873
by Rhinoman
Maybe not, I measured up the travel and spring compression on my JB 2" lift with Trailmaster extended shocks and I only needed 1/2" longer bumpstops.
Replied by Rhinoman on topic Bump stops
TomDK wrote: But..... It should be fairly obvious how much longer they need to be
Last edit: 04 Dec 2015 21:07 by Rhinoman.
04 Dec 2015 23:24 #157880
by Busta
Replied by Busta on topic Bump stops
Obviously you don't need to extend the bump stops the same amount as the lift, otherwise you'd not gain any extra travel from your expensive lift kit.
- TomDK
06 Dec 2015 22:06 #158001
by TomDK
You're right
Obviously I was just a bit too quick with my first reply :laugh: :laugh:
They should be extended roughly half the height of the suspension lift
Busta wrote: Obviously you don't need to extend the bump stops the same amount as the lift, otherwise you'd not gain any extra travel from your expensive lift kit.
You're right
Time to create page: 0.141 seconds
