Bump stops
- Rockwatt
TomDK wrote:
Easiest way of figuring out length of bump stop is to remove springs. Jack either end of Jimny up on stands and then use a jack to lift the axle up only the shock is fully compressed. Then is a matter of measuring how much longer the bump stop needs to be.
Thats a good idea! Ive heard that somewhere before I think
- TomDK
You probably have
- X8GGY
That should say "TomDK wrote" not what I "S200KYS wrote"...?
Rhinoman wrote: You also need to measure the gap left between the spring perches and then calculate the compressed length of the springs. Coil bind will kill the springs, its also pointless to fit extended bump stops if the spring is preventing them being used.
Why is everything so complicated?? :laugh: Thanks Rhinoman I will look into all of this and purchase a suitable bump stop
- X8GGY
