Can i swap m13a non vvt with m16a vvt ?( update )
  • wombat
19 Nov 2015 14:01 #156649 by wombat
Replied by wombat on topic Can i swap m13a non vvt with m16a vvt ?
I would suggest that you get someone who knows what they are doing to do the job
  • Mr.m.y
20 Nov 2015 06:35 #156690 by Mr.m.y
Replied by Mr.m.y on topic Can i swap m13a non vvt with m16a vvt ?
It seem i will replace the block
20 Nov 2015 06:58 #156692 by j999pre
I would fit the full vvt engine and see how it runs. If you don't like then swap the head for the non vvt jimny one. That way you may not need to do the head swap which would save a lot of work.
Grey pick up Jimny
The following user(s) said Thank You: Mr.m.y
  • Mr.m.y
20 Nov 2015 10:20 #156699 by Mr.m.y
thank you
good idea
i will try
thank you
  • Smoggy
20 Nov 2015 23:05 #156754 by Smoggy
Replied by Smoggy on topic Can i swap m13a non vvt with m16a vvt ?
j999pre wrote: I would fit the full vvt engine and see how it runs. If you don't like then swap the head for the non vvt jimny one. That way you may not need to do the head swap which would save a lot of work.
I don't think your Jimnys non vvt ecu will like the vvt engine. It doesn't have the ability to advance the timing in vvt form leading to overheating and timing issues.
21 Nov 2015 12:31 #156774 by kirkynut
My understanding is that you can use your 1.3 non vvt head on the 1.6 block which will do away with the vvt gubbins and run fine, even on the standard 1.3 map.
As long as they are both the same engine code save the capacity part. Ie: an M13a head on an M16a block.
