Can i swap m13a non vvt with m16a vvt ?( update )
- Mr.m.y
18 Nov 2015 16:12 - 23 Nov 2015 02:50 #156573
by Mr.m.y
Can i swap m13a non vvt with m16a vvt ?( update ) was created by Mr.m.y
Hi
It seem my jimny is non vvt
The problem is our market (Middle east ) only have swift m16a vvt or m15avvt
so i Think if i replace my jimny ecu and wire harness non vvt with Swift m16a vvt ecu and wire harness it will be possible
My idea it will work or no? there is any problem ?
Give your advice what i should do ?
The choices that i get till know
1- Swap only the block m13a block with m16a vvt block
2- Swap the engine vvt and connect cam sensor wire from the front of the head on a non vvt to the rear on a vvt
3- swap the engine and replace the ecu and wire harness for swift vvt ( maybe it not work )
if have idea tell me
which of 3 choices you prefer
i went to the market
I found Hundreds of VVt m15a engine from swift for each 400 $
also I found only one ( only one ) engine come from export of VVt m18a engine it cost 775 $ ( only one in our market )
and i found one I found engine of VVt m16a engine it cost 820 $
which one i should chose if you want reach more than 125 HP
Thank you
Thank you
Last edit: 23 Nov 2015 02:50 by Mr.m.y.
- Mr.m.y
18 Nov 2015 18:31 #156591
by Mr.m.y
Replied by Mr.m.y on topic Can i swap m13a non vvt with m16a vvt ?
any help ?
- Smoggy
18 Nov 2015 19:10 #156595
by Smoggy
Replied by Smoggy on topic Can i swap m13a non vvt with m16a vvt ?
I would say not. I paid a company called SPANNERMONKEYS from Newcastle way to fit me a 1.5 engine from a Suzuki Swift sport (which they also supplied). My car was a G13B non vvt (evident from its age as it was an X ref and they didn't even do vvt that year. However spanner@@nkeys fitted the vvt engine and subsequently overheated then blew up in the middle of a forest as many on here will testify. Morale of the story get a professional to do the work eg Rockwatt or Richie's Jimny not Spanner@@nkeys! Sorry to go on
- BENNY
18 Nov 2015 19:35 #156600
by BENNY
Replied by BENNY on topic Can i swap m13a non vvt with m16a vvt ?
richie"s jimny had a 1.6 liana in it .do a search on here see what comes up.
- Mr.m.y
19 Nov 2015 12:32 #156643
by Mr.m.y
can you send me the link
- Mr.m.y
19 Nov 2015 13:37 #156648
by Mr.m.y
I need help please
