Stability improvement.
  • TomDK
17 Feb 2015 17:20 #138201 by TomDK
Replied by TomDK on topic Stability improvement.
BGBrit wrote: Tom DK wrote...
Is you Jimny loaded up with cage, heavy batteries, winches and stuff? If so, get stiffer springs and shocks to match the weight of the car. Just going with soft springs no matter what does not improve off-road capability, it only makes it worse. Suspension parts needs to match the weight of the car.
Not with heavy batteries or winches, it will be full of camping gear, car-top boat and a Honda 1.3hp outboard motor a few necessary tools and two people. Plan on trips around Greece, Turkey and overseas to southern Italy. Some of their roads are pot-holed, plan on some off road driving too, to get to remote beaches. I'm using the Jimny as a touring camping van so too speak, which has good off the road abilities. I doubt very much I'll be driving on pay & play sites... I'll probably fit a cage to the top as it will be stronger than a roof rack for the boat, the boat by the way is plywood skinned in fibre-glass weigh's in at about 30 kgs.
Based on what you have said I think I should stiffen the springs, I drove across Europe speeds up to 80 mph, in the standard Jimny,, but now I'm home it will be driven more sedately (above 60 mph my wife panics.)
Cheers
BGBrit.
In that case, I can only recommend you to contact either you local ARB dealer or Trailmaster. They both supply a range of different springs to suit different needs and loads. Trailmaster also has a few different shocks. The ARB shock for Jimny is okay. Not made for heavy loads.
both have TÜV approved suspension kits.
19 Feb 2015 17:25 #138462 by BGBrit
Replied by BGBrit on topic Stability improvement.
Tom DK Thanks for that,, If only I new what ARB dealers are???? I will look into this as I'm sure this is a job I'll need to do..
Cheers Mate.
BGBrit.
  • TomDK
19 Feb 2015 17:53 #138465 by TomDK
Sorry :)
A supplier of ARB/Old man emu products :)
www.arb.com.au/
Time to create page: 0.084 seconds
