Stability improvement.
11 years 9 months ago #137904
by BGBrit
Stability improvement. was created by BGBrit
Hi All,
I'm thinking of adding some spaces to extend the tyres/wheels in the hope of adding a little more stability. Can any-one tell the max I should go to and do they add extra/adverse strain on the factory standard components.
Cheers
BGBrit (Tony)
Cheers
BGBrit (Tony)
11 years 9 months ago #137905
by facade
Replied by facade on topic Stability improvement.
They wear out the wheelbearings quicker, and you will have to notify your insurance.
There is nothing wrong with the stability now, spacers are normally fitted to get wheels/tyres on that don't have enough offset to clear the brakes.
(I suppose you could use them to get the track the same as a Landrover, to follow in their ruts
11 years 9 months ago #137911
by Busta
EFA
Spacers are a bit pointless unless you need them for clearance.
Replied by Busta on topic Stability improvement.
facade wrote: (I suppose you could use them to get the track the same as a Landrover, to increase the chance of getting grounded out in their ruts
EFA
11 years 9 months ago #137920
by BGBrit
Replied by BGBrit on topic Stability improvement.
Thanks for the feed back,,, I just thought they would help giving the Jimny a wider stance therefore stability,, I'll forego this addition in this case... Another job I don't need to do
Cheers BGBrit.
Cheers BGBrit.
- Reloaded
11 years 9 months ago #137921
by Reloaded
Replied by Reloaded on topic Stability improvement.
... or if you want to widen the track to compensate for the raised centre of gravity resulting from a suspension lift.
11 years 9 months ago #137934
by Busta
Stability for what? Jimny's don't just fall over
BGBrit wrote: Thanks for the feed back,,, I just thought they would help giving the Jimny a wider stance therefore stability,, I'll forego this addition in this case... Another job I don't need to do
Cheers BGBrit.
Time to create page: 0.091 seconds
