Stability improvement.
14 Feb 2015 13:03 #137904 by BGBrit
Hi All,
I'm thinking of adding some spaces to extend the tyres/wheels in the hope of adding a little more stability. Can any-one tell the max I should go to and do they add extra/adverse strain on the factory standard components.
Cheers
BGBrit (Tony)
14 Feb 2015 13:16 #137905 by facade
Replied by facade on topic Stability improvement.
They wear out the wheelbearings quicker, and you will have to notify your insurance.
There is nothing wrong with the stability now, spacers are normally fitted to get wheels/tyres on that don't have enough offset to clear the brakes.
(I suppose you could use them to get the track the same as a Landrover, to follow in their ruts ;) )
14 Feb 2015 14:03 #137911 by Busta
Replied by Busta on topic Stability improvement.
facade wrote: (I suppose you could use them to get the track the same as a Landrover, to increase the chance of getting grounded out in their ruts ;) )
EFA
Spacers are a bit pointless unless you need them for clearance.
14 Feb 2015 14:56 #137920 by BGBrit
Replied by BGBrit on topic Stability improvement.
Thanks for the feed back,,, I just thought they would help giving the Jimny a wider stance therefore stability,, I'll forego this addition in this case... Another job I don't need to do :)
Cheers BGBrit.
  • Reloaded
14 Feb 2015 14:57 #137921 by Reloaded
Replied by Reloaded on topic Stability improvement.
... or if you want to widen the track to compensate for the raised centre of gravity resulting from a suspension lift.
14 Feb 2015 17:45 #137934 by Busta
BGBrit wrote: Thanks for the feed back,,, I just thought they would help giving the Jimny a wider stance therefore stability,, I'll forego this addition in this case... Another job I don't need to do :)
Cheers BGBrit.
Stability for what? Jimny's don't just fall over ;)
Time to create page: 0.207 seconds
