Stability improvement.
15 Feb 2015 14:58 #138007
by facade
Replied by facade on topic Stability improvement.
With respect,
Are you chasing a problem that isn't there?
Stiffer springs will make the ride even more spine-jarring than it is now, and hurt the off road ability.
It is a small high sided vehicle, and in cross winds will go all over the place, you get used to it, just slow down a bit.
The steering is a 'box with long linkages, it will be a bit vague and the car tends to wander about slightly.
If you try to grip the wheel in fists of iron, chase the car and continually correct it, you seesaw about like Robbie the Robot in Fireball XL5 (On our way 'ome) and the car describes a series of tight S's.
A light touch on the wheel, and guiding it occasionally to keep it between the lane markings is all you need to do.
If you are experiencing the dreaded Death Wobble, or the car really is all over the place, then there is something wrong e.g. kingpins or worn bushes in the radius arms/panhard rods, fix them first.
15 Feb 2015 15:21 #138009
by BGBrit
Replied by BGBrit on topic Stability improvement.
I am, there is no problem with the Jimny, I guess I'm use to my Renault Laguna estate long wheel base wide and low too. I guess keeping the springs as stock is the way to stay,,, So, another job I don't need to do.
Thanks for all the advice,
BGBrit...
BGBrit...
- Panama1
16 Feb 2015 17:01 #138119
by Panama1
Replied by Panama1 on topic Stability improvement.
If you really want to improve the stability a little, here is the formula you will need: A vehicle's stability is measured by the formula---t/2h---where t is the 'track width' (center of the right front tire to the center of the left front tire) and h is the vehicle's center of gravity. When this number is 1.2 or greater, the vehicle is unlikely to roll
The quick answer is, the higher up the car is, the less stable.IE: if it has enough ground clearance to off-road, it is not very stable on-road. The absolute best way to improve stability on-road is to take your foot off the petrol.
- TomDK
16 Feb 2015 17:16 #138121
by TomDK
Is you Jimny loaded up with cage, heavy batteries, winches and stuff?
If so, get stiffer springs and shocks to match the weight of the car. Just going with soft springs no matter what does not improve offroad capability, it only makes it worse. Suspension parts needs to match the weight of the car.
Replied by TomDK on topic Stability improvement.
BGBrit wrote: I am, there is no problem with the Jimny, I guess I'm use to my Renault Laguna estate long wheel base wide and low too. I guess keeping the springs as stock is the way to stay,,, So, another job I don't need to do.
BGBrit...
16 Feb 2015 17:22 #138122
by BGBrit
Panama 1,, thanks for the advice, When I bought the Jimny in England I had it for a week or so before driving 2,500 miles across Europe to the Black Sea Coast, I did it in three days, driving alone in shifts of 6-8 hours driving and two hours sleep. Slept in the car's driver seat as the car was full of stuff to take home. Shifting my backside occasionally to let the blood flow I'd pull a little on the steering wheel and of course the Jimny wobbled a little. The speeds I doing,,, up to 80 mph. It sailed all the way there without any problems at all. I walked around for two days after a little stiff backed... I'm learning to drive it much slower now!!!
BGBrit.
BGBrit.
17 Feb 2015 10:02 #138180
by BGBrit
Tom DK wrote...
Is you Jimny loaded up with cage, heavy batteries, winches and stuff? If so, get stiffer springs and shocks to match the weight of the car. Just going with soft springs no matter what does not improve off-road capability, it only makes it worse. Suspension parts needs to match the weight of the car.
Not with heavy batteries or winches, it will be full of camping gear, car-top boat and a Honda 1.3hp outboard motor a few necessary tools and two people. Plan on trips around Greece, Turkey and overseas to southern Italy. Some of their roads are pot-holed, plan on some off road driving too, to get to remote beaches. I'm using the Jimny as a touring camping van so too speak, which has good off the road abilities. I doubt very much I'll be driving on pay & play sites... I'll probably fit a cage to the top as it will be stronger than a roof rack for the boat, the boat by the way is plywood skinned in fibre-glass weigh's in at about 30 kgs.
Based on what you have said I think I should stiffen the springs, I drove across Europe speeds up to 80 mph, in the standard Jimny,, but now I'm home it will be driven more sedately (above 60 mph my wife panics.)
Cheers
BGBrit.
Cheers
BGBrit.
Time to create page: 0.099 seconds
