Temp gauge
  • Vinnie
09 Sep 2014 21:48 #123767 by Vinnie
Replied by Vinnie on topic Temp gauge
steffan wrote: Nope thats hot it should sit level is the viscose fan working
Not sure what you mean (new to jimnys)
Cheers vinnie
09 Sep 2014 22:07 #123772 by kirkynut
Replied by kirkynut on topic Temp gauge
Yes the fan runs all the time but at different speeds depending on how locked up the viscous unit is which is controlled by the heat it generates. So the hotter the engine the more it locks up. You can lock it up completely or replace it with a known good one if it is at fault. I've heard of people trying to stop it with a newspaper and if it stops really easily then it has had it.
The thermostat is usually where the radiator top hose meets the block, but I think you have a single cam engine and it's a long time since I had one of those.
  • Vinnie
09 Sep 2014 22:20 #123774 by Vinnie
kirkynut wrote: Yes the fan runs all the time but at different speeds depending on how locked up the viscous unit is which is controlled by the heat it generates. So the hotter the engine the more it locks up. You can lock it up completely or replace it with a known good one if it is at fault. I've heard of people trying to stop it with a newspaper and if it stops really easily then it has had it.
Ok I'll try to stop it tomorra
I've got a double over head.
Is the thermostate in the end of the square Ali bit on front of engine ?
Cheers vinnie
10 Sep 2014 06:12 - 10 Sep 2014 06:15 #123780 by j999pre
Replied by j999pre on topic Temp gauge
Your thermostat will be under the inlet manifold behind the water pump in the black plastic housing.
Did they fit the correct temp rad cap? Is their water in the expression bottle? Add people have said it could be the fan. Any blocked fins on the rad or air con rad not letting air through?
It could even be a dodgy temperature sender (at the back of the head).
Grey pick up Jimny
Last edit: 10 Sep 2014 06:15 by j999pre.
  • Vinnie
10 Sep 2014 16:38 #123808 by Vinnie
j999pre wrote: Your thermostat will be under the inlet manifold behind the water pump in the black plastic housing.
This is the cap fitted ?
Is that the thermo the rounded ended thing with large coolant hose ?
Yes water in bottle a take rad cap off water in ther also
  • Vinnie
10 Sep 2014 16:40 #123809 by Vinnie
Looks nice to get too lol.
The fan will twist round by hand easy is this correct ?
Cheers vinnie
Time to create page: 0.107 seconds
