Temp gauge
  • Butta
14 Sep 2014 15:17 #124083 by Butta
Replied by Butta on topic Temp gauge
If both heater pipes are hot I would say it was ok because it works like a little radiator so one will be hotter than the other your problem is most likely elsewhere if it was my truck I would drain the coolant remove, flush and examine the rad to check for blockages and damage if this seems in order I would look at the water pump/drive also have you cheked the thermostat yet? It may be stuck so its letting some water through but not fully opening if not remove it put it in a pan and heat it up until it opens if it doesn't before the water boils its knackered
  • Vinnie
14 Sep 2014 15:38 #124086 by Vinnie
Replied by Vinnie on topic Temp gauge
Butta wrote: If both heater pipes are hot I would say it was ok because it works like a little radiator so one will be hotter than the other your problem is most likely elsewhere if it was my truck I would drain the coolant remove, flush and examine the rad to check for blockages and damage if this seems in order I would look at the water pump/drive also have you cheked the thermostat yet? It may be stuck so its letting some water through but not fully opening if not remove it put it in a pan and heat it up until it opens if it doesn't before the water boils its knackered
Was hoping to find the problem before having to take the thermostat out as it looks a mare to get to
  • Butta
14 Sep 2014 15:44 #124087 by Butta
Sorry fella but unless its the rad cap as already discussed and your fan belt is tight (not slipping as it drives the water pump) your gonna have to get the socket set out and start stripping stuff off
  • Vinnie
14 Sep 2014 19:21 #124101 by Vinnie
Butta wrote: Sorry fella but unless its the rad cap as already discussed and your fan belt is tight (not slipping as it drives the water pump) your gonna have to get the socket set out and start stripping stuff off
I've had a look and taking the air hose of to throttle body can get to nuts I think. Cheers vinnie
  • Vinnie
06 Dec 2014 16:06 #131693 by Vinnie
Well I think I may have fixed the overheat problem.
Removed the heater matrix pipes to see if matrix was blocked connected hose and flushed it through and was ok reconnected pipes back up tried it and heater blew hot and temp gauge stayed on half way left it running for about forty mins and was all good. So may of just been an air lock in heater matrix like someone suggested HAPPY days :cheer:
Time to create page: 0.090 seconds
