Temp gauge
- Vinnie
12 years 2 months ago #123751
by Vinnie
Temp gauge was created by Vinnie
Took jim jam on a 150 mile trip to gatwick last weekend,first time on long run as haven't had it long drove about 3/4 of an hour and noticed temp gauge was going up was only doing 60/65 so backed off to 50 and it went down a little but then went up again,So I put the heater on to take heat away from engine as you do when track racing,temp went down then back up (same 50 speed) it went up to line as photo and never went over it apart from when we stopped in garage I turned car off and the gauge jumped up to max then to zero then engine stopped.Had stopped for about 10 mins and carried on with journey temp gauge was at half way then rose back up near line,Car never over heated or lost water but the heater sometimes blew hot and sometimes cold,
Before I got the car it had had a head gasket,head skim,new rad,hoses,rad cap,air con pump etc could this just b a dodgy gauge or wiring or maybe an air lock ? It's had a replacement dash dials also not new though.
Cheers vinnie
Cheers vinnie
- Vinnie
12 years 2 months ago #123752
by Vinnie
Replied by Vinnie on topic Temp gauge
Forgot to add photo.
Is this a normal running temp for jimnys ?
Cheers vinnie
Cheers vinnie
12 years 2 months ago #123761
by kirkynut
Replied by kirkynut on topic Temp gauge
Could be thermostat stuck a bit shut or the viscous unit on the fan is not locking up when it ought to. I wonder if you are dealing with the reason it had all the work done to it and they never fixed it.
No that is far too high in the piccie - should be about half way only.
- parriehunter
12 years 2 months ago #123762
by parriehunter
Replied by parriehunter on topic Temp gauge
No it is not, mine sits just below half.
Maybe a dodgy thermostat.
- steffan
12 years 2 months ago #123763
by steffan
Replied by steffan on topic Temp gauge
Nope thats hot it should sit level is the viscose fan working
- Vinnie
12 years 2 months ago #123765
by Vinnie
The fan runs all the time don't they ? Where is the thermostats ? In hose on front of engine above radiator ?
Cheers vinnie
kirkynut wrote: Could be thermostat stuck a bit shut or the viscous unit on the fan is not locking up when it ought to. I wonder if you are dealing with the reason it had all the work done to it and they never fixed it.
Cheers vinnie
Time to create page: 0.107 seconds
