Temp gauge
  • Vinnie
14 Sep 2014 13:00 #124059 by Vinnie
Replied by Vinnie on topic Temp gauge
Thinking about it I guess that's right.hot at top fan cooling water to put cold into engine right
  • Vinnie
14 Sep 2014 14:15 #124068 by Vinnie
Just left car on idle for 3/4 of hour with radiator cop off and heater on to see if any air trapped,temp gauge didn't get up to half way but heater still not hot ?
  • Butta
14 Sep 2014 14:39 #124073 by Butta
Replied by Butta on topic Temp gauge
If I start my m13a jimny and leave to idle heater is hot in 5-10mins and temp gauge has never gone above half unless my rad is full of mud so sounds like air lock maybe in heater matrix
  • Vinnie
14 Sep 2014 14:43 #124075 by Vinnie
Butta wrote: If I start my m13a jimny and leave to idle heater is hot in 5-10mins and temp gauge has never gone above half unless my rad is full of mud so sounds like air lock maybe in heater matrix
Cheers did you read my first post ? When driving its get hot
  • Butta
14 Sep 2014 14:56 #124078 by Butta
yes where you said it sometimes blew cold even when temperature was high because the water pump pumps all the time the engine Iis runningthe heater should always get hot coolant so should always blow hot (if the engine is hot enough) with my temp gauge on half and my heater on hot it feels like its burning my legs if the heater is not always hot its not always getting hot coolant which usually means low coolant, air lock or heater matrix blocked and any of these could cause over heating
  • Vinnie
14 Sep 2014 15:04 #124080 by Vinnie
Both pipes to the heater matrix are hot one more than the other and if I put and on heater matrix inside its warm.Do you know best way to get air lock out if its or one ?
Cheers vinnie
Time to create page: 0.106 seconds
