Brake problem
- JimnyRiddle
05 Sep 2014 23:11 #123437
by JimnyRiddle
Ye I thought they were spotless when I rebuilt them. I forgot to mention it's both front brakes binding slightly so I doubt that both calipers have a bit of crap in them. I dunno, hopefully I'll figure it out. Thanks for the advice
Cheers
Mike
Replied by JimnyRiddle on topic Brake problem
robs5230 wrote: with the hit and miss sticking i'd say there's some crap in there somewhere. its ok putting new pistons and sliders in but the caliper body has to be absolutely clean. hope you get it sorted mate
Cheers
Mike
06 Sep 2014 07:06 #123442
by kirkynut
Replied by kirkynut on topic Brake problem
What are we calling binding? The slight noise of the pads touching the disc ever so slightly or tricky to turn by hand?
- JimnyRiddle
06 Sep 2014 07:29 #123447
by JimnyRiddle
I can turn the wheels by hand and you can feel it grabbing, but you can't spin it freely.
Mike
kirkynut wrote: What are we calling binding? The slight noise of the pads touching the disc ever so slightly or tricky to turn by hand?
Mike
06 Sep 2014 08:21 #123449
by kirkynut
Ok then. When you re-built them did you use new slider tubes or greased up the old ones?
I think you said it came with new ones but trying to cover all angles. Just wondering if you re-used the old ones and they are pitted or in any way not smooth if they are grabbing rather than running smoothly through, despite the grease.
I'm starting to wonder about the master cylinder otherwise but I'm struggling to think why it would behave like this, especially as it took the fluid back when you pushed the pistons in for the pads.
06 Sep 2014 08:25 #123450
Replied by mlines on topic Re:Brake problem
Did you change the slider boots? And did you use the correct grade for the sliders (not oil based)
Sent from my Nexus 5 using Tapatalk
- GuardianAngel
06 Sep 2014 08:52 #123453
by GuardianAngel
Replied by GuardianAngel on topic Re:Brake problem
I wet and dry the sliders and tubes to get them super shiny again. Then run some red grease over them and the inside of the boots.
Time to create page: 0.253 seconds
