Brake problem
Perhaps put a wire brush in a drill or on an angle grinder and give them a really good going over.
If that doesn't stop it then look at the anti vibration springs the pads sit in. They are a right pain and I don't think it's the end of the world if you run without them. You could try running without them for a short while to see if it causes an issue and if it solves the problem.
- JimnyRiddle
kirkynut wrote: I know you said you cleaned the calliper mounts where the pads go in but the rust can really make the area they slide in tighter and thus cause them to stick, especially as they get hot and expand.
Ye I'll try that and see how I get on thanks man
Cheers
- Wiltec17
- JimnyRiddle
Wiltec17 wrote: Like kirky said, check the pads are freely moving in the carrier, sounds like they could be sticking/corroded in there mount. We have this issue all the time at work
a good wire brush and plenty of copper slip
I replaced the kingpin bearings today and checked the pad carriers, they're free and have a nice bit of copper grease on them. I'll try removing them and see if that makes a difference. If all else fails I'll swap the master cylinder and see if that cures it.
Cheers
Mike
- JimnyRiddle
Mike
