Brake problem
Sent from my Nexus 5 using Tapatalk
JimnyRiddle wrote:
I can turn the wheels by hand and you can feel it grabbing, but you can't spin it freely.
Mike
They are supposed to drag slightly, otherwise the pads will chatter and the pedal will go right down the first time you press them.
Is this what you have?
(Unlike a pushbike, where the pads are designed to come right off so it is easier to pedal)
- JimnyRiddle
- JimnyRiddle
mlines wrote: Did you change the slider boots? And did you use the correct grade for the sliders (not oil based)
Ye I renewed the boots and used red rubber grease...
- JimnyRiddle
facade wrote:
Mike
I don't think the pads should be touching the disc until you press the pedal down. They should stay close but not drag, but I should be able to spin the wheel freely. As it is with them slightly binding, I'm suffering poorer fuel economy and brakes getting hotter than they should.
- JimnyRiddle
GuardianAngel wrote: I wet and dry the sliders and tubes to get them super shiny again. Then run some red grease over them and the inside of the boots.
Ye did all that man..
