Brake problem
  • JimnyRiddle
04 Sep 2014 20:04 #123376 by JimnyRiddle
Brake problem was created by JimnyRiddle
Hi all, I've a problem with the Jimny brakes binding very slightly. It doesn't happen all the time and there doesn't seem to be a certain time when it does it.
When I bought the Jimny I noticed that the discs were due for replacement so I ordered new discs and pads. While fitting those I noticed that the last owner had decided to rip the piston boots to bits, I assume when replacing brakes previously and that the pistons had some water ingress. So I ordered two caliper rebuild kits including new pistons, which I fitted and carried out a full brake fluid flush. This is when I noticed the brakes binding slightly. After doing a bit of googling and forum searching, a bigjimny member had posted about flexi pipes collapsing internally and restricting fluid return causing brake binding. So with a suspension lift in mind I ordered and fitted extended stainless brake pipes, and again I renewed the brake fluid. Brakes still slightly binding!! More googling and forum searching later, another bigjimny member mentioned about a brake pedal adjustment that the had adjusted and fixed his binding brakes after front brake replacement. So I had a play with this and eureka, no binding brakes for two days and then binding brakes again! Other than a faulty master cylinder, what could it be? I'm at a loss. Does anyone have any ideas?
Cheers
Mike
05 Sep 2014 06:34 #123386 by robs5230
Replied by robs5230 on topic Brake problem
did you rebuild the sliders in the calipers. this must be the biggest cause of binding brakes. when i rebuilt mine, the sliders looked like they had been at the bottom of the sea for 10 years. never seen so much encrusted rust on anything before.
standard jimny - for now
  • JimnyRiddle
05 Sep 2014 12:41 #123395 by JimnyRiddle
Replied by JimnyRiddle on topic Brake problem
robs5230 wrote: did you rebuild the sliders in the calipers. this must be the biggest cause of binding brakes. when i rebuilt mine, the sliders looked like they had been at the bottom of the sea for 10 years. never seen so much encrusted rust on anything before.
Hi Rob. Ye I renewed them all and rubber boots, they came with the rebuild kit. They weren't really corroded. I even bought the correct red rubber silicone based grease. I dunno tis a weird one!
Mike
05 Sep 2014 19:55 #123424 by kirkynut
Replied by kirkynut on topic Brake problem
So you've replaced the slider tubes themselves? Is that right? The tubes that the little rubber boots sit on the ends of that are fiddly to get to stay in place as you fit them?
What about the calipers? Did you rebuild them. They could be sticking themselves.
  • JimnyRiddle
05 Sep 2014 21:08 #123430 by JimnyRiddle
kirkynut wrote: So you've replaced the slider tubes themselves? Is that right? The tubes that the little rubber boots sit on the ends of that are fiddly to get to stay in place as you fit them?
Ye they were renewed and both front calipers completely rebuilt, new pistons,seals and boots. I've had the calipers off the hub and they pump out easily and are easy to push back. Pad carriers are clean and copper greased.
05 Sep 2014 21:47 #123435 by robs5230
with the hit and miss sticking i'd say there's some crap in there somewhere. its ok putting new pistons and sliders in but the caliper body has to be absolutely clean. hope you get it sorted mate
Time to create page: 0.105 seconds
