Adjusting the ignition timing
- Benjiboi
24 Feb 2014 12:49 #105823
by Benjiboi
Replied by Benjiboi on topic Adjusting the ignition timing
How do you know what number resistor to get or do you just keep trying until it feels better?
24 Feb 2014 13:20 #105828
by Rhinoman
Replied by Rhinoman on topic Adjusting the ignition timing
You need to check the timing and then note how far out it is. If it is, for example, -2 degs then you should check the resistor currently fitted, if its a 2 degree resistor then you need a +4 degree resistor.
- Blackie
04 Apr 2017 07:43 #179898
by Blackie
Replied by Blackie on topic Adjusting the ignition timing
Can someone please confirm for me, is this the Timing Trim Resistor?
it has number 4 on it.
After bridging the monitor coupler and using a timing light, I got the figure of "0" TDC.
Can someone please shed some light on which resistor I need to purchase to get my timing back to stock "5 BTDC".
also where to purchase from. I live Adelaide South Australia
Thankyou
Blackie
First Time Poster.
Thankyou
Blackie
First Time Poster.
06 Apr 2017 20:22 - 06 Apr 2017 20:26 #179988
by Rhinoman
As far as I can tell you need to add 5 degrees to the timing, you already have a 4 which is -2 degrees so you would need a +3 degree which would be an '8'. The difference should be quite noticeable.
You could pick up a 2k2 1/2W resistor and connect it using spade terminals to test that, it would be a cheap test.
Last edit: 06 Apr 2017 20:26 by Rhinoman.
The following user(s) said Thank You: Blackie
- OllieNZ
07 Apr 2017 10:40 #180020
by OllieNZ
Replied by OllieNZ on topic Re:RE: Adjusting the ignition timing
What wattage variable resistor would you recommend for testing purposes?Rhinoman wrote: As far as I can tell you need to add 5 degrees to the timing, you already have a 4 which is -2 degrees so you would need a +3 degree which would be an '8'. The difference should be quite noticeable.
07 Apr 2017 10:59 #180021
by Rhinoman
Replied by Rhinoman on topic Re:RE: Adjusting the ignition timing
1/2 watt would be more than sufficient. If my memory is to be relied upon then the value of the resistor is only read at key on so you can't adjust it on the fly.
Time to create page: 0.372 seconds
