Adjusting the ignition timing
  • OllieNZ
07 Apr 2017 12:35 #180023 by OllieNZ
Replied by OllieNZ on topic Re:RE: Re:RE: Adjusting the ignition timing
Rhinoman wrote: 1/2 watt would be more than sufficient. If my memory is to be relied upon then the value of the resistor is only read at key on so you can't adjust it on the fly.
Thanks.
Do you mind if I pm you with some other questions unrelated to this topic?
  • Blackie
08 Apr 2017 10:29 #180062 by Blackie
Replied by Blackie on topic Adjusting the ignition timing
Thanks ever so much for your time and effort replying, I managed to get 6 degrees adjustment by elongating the holes in the cam sensor cover and rotating it. Now to see how much difference it may make in the running of the vehicle. Thanks again.
08 Apr 2017 11:14 #180063 by Rhinoman
OllieNZ wrote: Do you mind if I pm you with some other questions unrelated to this topic?
No problem
  • niki 76
20 Apr 2017 05:53 #180423 by niki 76
Replied by niki 76 on topic Adjusting the ignition timing
Hello,
I аm from Bulgaria,
I removed this resistor completely, for maximum advance and drive without it, but I do not feel any difference
20 Apr 2017 07:40 #180424 by Rhinoman
Have you checked that it is actually advanced? I would expect no resistor to cause it to default to full retard.
  • niki 76
20 Apr 2017 08:41 #180426 by niki 76
I do not want actually advanced, I want maximum advanced, because I drive my Jimny with LPG(Liquefied Petroleum Gas)
