Adjusting the ignition timing
22 Jul 2020 11:22 #225458 by Old Neil
Rhinoman wrote: I was talking to someone about remapping the G13BB Jimny. We were discussing modifying the base timing using the trim resistor but searching through Google for a link I found no information on this so I wonder how many people have actually checked their timing. The FSM does explain how to do it but it seems that many people believe that its not adjustable. For information I've compiled a table of the stock resistor values and part numbers:
Part Number, Mark, Resistance (ohms), Advance (correction)
33926-76G10, 1, 0, -5
33926-76G20, 2, 82, -4
33926-76G30, 3, 160, -3
33926-76G40, 4, 270, -2
33926-76G50, 5, 430, -1
33926-76G01, N, 680, 0
33926-76G60, 6, 1000, 1
33926-76G70, 7, 1500, 2
33926-76G80, 8, 2200, 3
33926-76G90, 9, 3600, 4
33926-76GA0, 10, 6200, 5
33926-76GB0, 11, 12000, 6
There should be a sticker on the timing cover that indicates which resistor is currently fitted. Timing advance should be fixed using a jumper in the monitor coupler before checking timing. It is possible to fit a variable resistor in place of the fixed resistor.
Edit: My apologies for the formatting - it looks OK in the editor.
Hi Rhinoman
I found this old post of yours, didn't know this was possible thanks so much
Neil
  • ozputu
09 Sep 2021 03:44 #238375 by ozputu
Replied by ozputu on topic Adjusting the ignition timing
Hi Rhinoman where is the resistor located, and what pins do you jumper on the test plug
07 Oct 2026 09:53 #265360 by gndautogrenada
I have this exact same issue. Did you find a solution ?
07 Oct 2026 21:30 #265362 by fordem
What issue? What engine?
Time to create page: 0.797 seconds
