Adjusting the ignition timing
20 Apr 2017 08:53 #180427 by Rhinoman
Have you used a timing light to check that the ignition is more advanced without the resistor fitted? I would expect no resistor to be a fault condition which would cause the ECU to go to full retard. To get maximum advance you would need to fit the '11' resistor and then slot the mountings if that is not enough.
20 Apr 2017 19:17 #180438 by Keithy
Going full retard is searchable on youtube Rhinoman :D
Niki when I looked into LPG it seems that I'll need switchable maps due to the extra duration of injection It requires for the LPG injectors...
How does your system interface as the ones I've looked at merely modify the outputs from the standard ECU in a piggy back fashion.
  • niki 76
21 Apr 2017 06:10 #180444 by niki 76
Replied by niki 76 on topic Adjusting the ignition timing
I do nоt know, how does my system interface modify the outputs
Now, i put 12000 ohms resistor to tray
  • niki 76
21 Apr 2017 10:25 #180449 by niki 76
I used a timing light to check the advance without resistor and it is like mark N (0 correction)
21 Apr 2017 10:40 #180451 by Rhinoman
niki 76 wrote: I used a timing light to check the advance without resistor and it is like mark N (0 correction)
Ah OK, it defaults to no correction rather than full retard - its a while since I looked at this.
22 Sep 2017 07:37 #184321 by yakuza
Does anyone know if this is the same in m13a/m16a engines?
I got ignition pinging due to change in compression rate from 9.5(m13a) to 11.1(m16a)
Time to create page: 1.168 seconds
