Adjusting the ignition timing
20 Feb 2014 14:09 - 20 Feb 2014 14:15 #105288 by Rhinoman
I was talking to someone about remapping the G13BB Jimny. We were discussing modifying the base timing using the trim resistor but searching through Google for a link I found no information on this so I wonder how many people have actually checked their timing. The FSM does explain how to do it but it seems that many people believe that its not adjustable. For information I've compiled a table of the stock resistor values and part numbers:
Part Number, Mark, Resistance (ohms), Advance (correction)
33926-76G10, 1, 0, -5
33926-76G20, 2, 82, -4
33926-76G30, 3, 160, -3
33926-76G40, 4, 270, -2
33926-76G50, 5, 430, -1
33926-76G01, N, 680, 0
33926-76G60, 6, 1000, 1
33926-76G70, 7, 1500, 2
33926-76G80, 8, 2200, 3
33926-76G90, 9, 3600, 4
33926-76GA0, 10, 6200, 5
33926-76GB0, 11, 12000, 6
There should be a sticker on the timing cover that indicates which resistor is currently fitted. Timing advance should be fixed using a jumper in the monitor coupler before checking timing. It is possible to fit a variable resistor in place of the fixed resistor.
Edit: My apologies for the formatting - it looks OK in the editor.
Last edit: 20 Feb 2014 14:15 by Rhinoman.
  • blitzn
20 Feb 2014 15:23 - 20 Feb 2014 15:37 #105292 by blitzn
Replied by blitzn on topic Adjusting the ignition timing
Another way you can do it with the G Series engines is to slightly drill out the 3 allocation/mounting holes bigger for the Cam Sensor Housing. I put the G16a in my Jimny and still wasnt happy with it running at 10 degrees. Drilled out these holes a couple of mm bigger and it allows you to rotate the cam sensor like a distributor. Put a timing light on and you are good to go. Think the most i could get was 13-14 degrees However. It made the world of difference in performance.
If i remember right you could only drill a couple of mm bigger before hitting the o'ring seal. Still enough to slightly rotate the cam sensor housing enough to bump up (or down) the timing a little.
Still Rhinoman's way is best.
Last edit: 20 Feb 2014 15:37 by blitzn.
  • gus2000
21 Feb 2014 20:59 #105467 by gus2000
Replied by gus2000 on topic Adjusting the ignition timing
Hello, the timing correction is very interesting.
whereas gasoline that the engine G13BB was designed differs substantially from that used currently
in joint work with carlos (carlos hma from chile) experimentally determine the optimum ignition point
Factory ignition point
Carlos hma replaces the original fixed resistor for a variable resistor (lineal 20kohm)
And the ignition timing is adjusted while driving :)
Found the ignition point works best satisfies us, we replace the variable resistor for a fixed one.
Cheers
Gustavo
  • Yellostreak
22 Feb 2014 03:36 - 22 Feb 2014 03:50 #105489 by Yellostreak
Replied by Yellostreak on topic Adjusting the ignition timing
Rhinoman wrote:
There should be a sticker on the timing cover that indicates which resistor is currently fitted. Timing advance should be fixed using a jumper in the monitor coupler before checking timing. It is possible to fit a variable resistor in place of the fixed resistor..
would say there is no reason why you could not fit a 10k 25 turn pot/trimmer to replace the resistor that's fitted.. something like this:
LINK
The manual say s the ignition resistor is behind the glovebox but have you got a photo of where the sticker is as I cannot see one on mine :(
Last edit: 22 Feb 2014 03:50 by Yellostreak.
  • gus2000
22 Feb 2014 11:18 - 22 Feb 2014 11:20 #105503 by gus2000
Resistor in my jimny. (LHD)
Marked with number 2
Last edit: 22 Feb 2014 11:20 by gus2000. Reason: Redaccion incomplete
22 Feb 2014 12:03 - 22 Feb 2014 12:13 #105507 by Rhinoman
You could use a variable resistor like that one, the CO adjusters fitted on General market models are just that mounted to a connector. This one is from a Swift:
There should be a sticker on the timing cover like this one (borrowed from the net):
You need to be cautious when experimenting with the timing but if it hasn't been checked then there could be gains in power and economy from getting it set to the stock settings.
Last edit: 22 Feb 2014 12:13 by Rhinoman.
Time to create page: 0.189 seconds
