Tyre Sizes - Rough Guide Thread
25 Nov 2013 05:57 - 18 Dec 2014 08:47 #93064 by Lambert
Ok lets see if I have this right.
205.70.15 stock size no rubbing regardless of pattern.
195.80.15 no lift needed for ht or at but mt might catch depending on pattern
215.75.15 needs a minimum of 2 inch lift or mucho arch cutting depending on wheel offset, factory wheels with no spacers ought to be ok with no lift and minor trimming depending on pattern.
235.75.15 needs 3to4 inch of lift and some cutting
31.1050.15 needs 4 plus inch of lift plus some body lift plus some arch cutting.
Bumper design will have a part to play with how much or not has to be trimmed pre 05 needing less post needing more.
Also as we know just because a tyre says the size on the side doesn't follow that another tyre from a different manufacturer with the same size markings will be exactly the same, remanufactured tyres tend to be worse for sizing accuracy.
This list is not exhaustive and is intended only for guidance. The information contained is garnered solely from the Internet and not from the experience of the author. It is recommended that you contact the suppliers of your choice of tyre for exact dimensions and confirm those against the nominal sizes and decide appropriately if you want to go ahead. You are responsible for your own actions.
Can anyone add to the list and any chance a mod could sticky it?
Last edit: 18 Dec 2014 08:47 by kirkynut.
  • piprice
25 Nov 2013 07:50 - 25 Nov 2013 07:53 #93068 by piprice
Replied by piprice on topic tyre size
I can say that with out spacers I run 215/75/15 with no issues or lift.
As soon as I whacked spacers on that was it and lifting didn't do a lot to help the rubbing either so I only done a little cutting at the front and I now need to do a little at the back on the inner arch, the front was just a bit of the lower bumper.
Not been off road yet, so couldn't say what articulation will be like.
Others will be along soon to help and clarify
I done a lot of search on this and found 215/75 will not effect anything like gearing etc
Last edit: 25 Nov 2013 07:53 by piprice.
  • TomDK
25 Nov 2013 11:44 #93082 by TomDK
Replied by TomDK on topic tyre size
235/75/15 on a 2" suspension lift works okay. If they're remoulds some trimming might be needed.
  • jonesyba420
25 Nov 2013 11:59 #93086 by jonesyba420
Replied by jonesyba420 on topic tyre size
I run 195 80 15 kumho kl71 mud tyres with no lift, cant say ive noticed any rubbing etc and ive had it pretty flexed.they do get very close tho ;)
Id say they would definately rub with spacers.
would highly recomend them and they get top reviews, there pretty god on the road both in wet or dry and dont seem to have effected economy to much.
  • GuardianAngel
25 Nov 2013 12:04 #93088 by GuardianAngel
Replied by GuardianAngel on topic tyre size
jonesyba420 wrote: I run 195 80 15 kumho kl71 mud tyres with no lift, cant say ive noticed any rubbing etc and ive had it pretty flexed.they do get very close tho ;)
I've pretty much decided I'm going to get these tyres, but I will probably fit a small spring spacer lift as well.
  • jonesyba420
25 Nov 2013 12:44 - 25 Nov 2013 12:45 #93091 by jonesyba420
good choice i hope your not dissapointed (i know i havent been so far), they coped very well with salisbury plain clay/mud. idiotmobil can give an idependant review from a bystanders perspective as he was there.
went laning yesterday, heres a 5 min vid of a local lane towards the end you can see it flexing as i drive down a bank, the wheel dissapears into the arch pretty well and no rubbing but i dont know how much more it can flex so may rub after that:
Last edit: 25 Nov 2013 12:45 by jonesyba420.
Time to create page: 0.103 seconds
