THE DEATH WOBBLE THREAD
26 Feb 2015 19:07 #139237
by kirkynut
Replied by kirkynut on topic THE DEATH WOBBLE THREAD
I've seen that before but it makes great sense to have it in this thread, so thank you Mark.
The movement of the hub over the swivel due to the king Pins being shot is massive!
The topic has been locked.
- rogerzilla
13 Apr 2015 07:46 #142369
by rogerzilla
Replied by rogerzilla on topic THE DEATH WOBBLE THREAD
Assuming the kingpins are in good condition and you have a steering damper (recent Jimnys) then the problem is usually solved by removing the front wheels and refitting them carefully. Clean the hub, use a bit of copper grease to prevent sticking and tighten the wheel nuts progressively and evenly (i.e. go round the hub tightening every other nut until you've done all five) by hand, first just tight enough to lower the car back to the ground, then using a torque wrench first set to about 70Nm and then set to the full torque of 100Nm or whatever is recommended for your wheels.
I have never had shimmy when I've fitted the wheels. When the dealer has fitted the wheels there has always been shimmy until I've taken them off and done them again. They generally just whack them on with an air gun and the wheel can end up ever so slightly eccentric on the hub. The sightest eccentricity is magnified by beam axle suspension.
14 Apr 2015 20:47 #142481
by Rhinoman
The part number is moulded into the bush, you may be able to see it without removing anything.
Replied by Rhinoman on topic THE DEATH WOBBLE THREAD
Halford wrote: wonder if this is the older style control arm rear bush issue that Suzuki have reported on Jimny's up to VIN JSAFJB43V00422454 ... my 2007 truck has an earlier VIN than this
- Decklandpt
08 May 2015 12:58 #143886
by Decklandpt
Replied by Decklandpt on topic THE DEATH WOBBLE THREAD
Just gonna leave my experience with the wooble.
I had a ddis jimny with insaturbo dakars (m/t tread). i had some wobble at around 80kmh (40/50mph), but it only happened like, in the morning, or at least, after the car had been parked for a few hours, and it only happened during the first couples of miles, then it went away. i har heard that retreaded tires could change shape when parked for some time...
then, that jimny met an untimely demise in a head on colision...so i got me another one, this time a 1.3 dohc...
it came with the vitara alloys, and some really old duellers. the front tires where worn out on the outside on both sides, and the rear ones looked almost new, except for the fact the rubber was dry.
at first, every time i reached 40/50 mph onwards till the top speed, the whole car vibrated like hell. it didn't affect the trajectory, but the steering wheel and the gear knobs where shaking like michael j. fox. wheel and rim calibration was fine.
So, to test it out, i switch the tires from one axel to the other, front to rear, rear to front... it helped. now it only wobbled between 40 and 50. so i was decided to check on the bearings, but since i needed tires as well, i decided to get a new set first, not retreaded, as they can be a pain to calibrate. got a set og hankook dynapro atm fr10 and it just went way.
- virginian
10 May 2015 11:13 #143978
by virginian
Replied by virginian on topic THE DEATH WOBBLE THREAD
While fitting a set of wheel spacers I decided to kill two birds with one stone & eradicate the 45mph wheel wobble I had suffered since adopting the jimny a month ago.
Removing both front wheels first, I scrubbed off the 10 year old crud from the inside of the 3 spoke alloys ( there are 3 deep pockets which were caked in rust & brake dust) All 4 tyres were nearly new Duellers with equal amounts of tread. I re-balanced the fronts, with the n/s wearing a 30g weight & spot on, the o/s also wearing a 30g weight but subsequently only requiring a 10g weight :dry:
The rears were treated in the same fashion & everything refitted without too much drama.
A subsequent road test provided no wobble at normal driving speeds up to 70mph & back, though some shimmying could be felt over manholes / road patches etc :laugh: There was a definite improvement to stability which I imagine would be down to the spacers I fitted.
I'm led to believe that the fronts especially, are prone to imbalance over time , due to wear & road surface damage & should be balanced
whenever the opportunity presents itself. ( sounds like I own a wheel balancing business )
- reflexsa
28 May 2015 10:49 #144956
by reflexsa
Replied by reflexsa on topic THE DEATH WOBBLE THREAD
I can feel the death wobble wanting to start when I go over bumps. The steering is perfect under normal circumstances.
Braking seems to amplify the problem (discs are not warped). I have superpro bushes on the front panhard and I see someone else mentioned that it was the cause of their problem. I'm a bit sceptical. Has anyone else experienced this?
Time to create page: 0.296 seconds
