Can I tow I tow a lightweight Caravan with a Jimny
  • gilburton
22 Nov 2013 18:33 #92642 by gilburton
Are you drilling a hole in the wheel cover behind the plate for the wiring?
I might do that on mine then the plug can be behind the plate.
  • Ruby2
22 Nov 2013 18:51 #92644 by Ruby2
Yes the number plate wiring is fed through a hole between the centre of the bushes. :-)
  • gilburton
22 Nov 2013 19:41 #92652 by gilburton
You can also use your old number plate on the caravan :)
  • Ruby2
27 Nov 2013 18:03 #93454 by Ruby2
@Gilburton thanks for your help it's all done and wired in.
To be fair I used a speaker cable as it was two wires together, but I'm concerned about it rubbing through. I'm not too concerned with the load on the cable as the lights just a LED lamp so I doubt it'll use many amps.
So I may use thicker wire :-/
Here are some pics now it's done.
Thanks again for your help
  • gilburton
27 Nov 2013 18:14 #93457 by gilburton
Looks neat :)
  • Ruby2
27 Nov 2013 18:41 #93461 by Ruby2
Cheers ;-)
gilburton wrote: Looks neat :)
Time to create page: 0.225 seconds
