2low switch.
  • X8GGY
31 Oct 2014 15:14 #128024 by X8GGY
Replied by X8GGY on topic 2low switch.
gaz3359 wrote: show off !
Busted! ;)
  • S Mark
31 Oct 2014 21:27 #128045 by S Mark
Replied by S Mark on topic 2low switch.
It all seams so simple think I will get myself a switch. ASAP :cheer:
  • oilypirate
01 Nov 2014 21:18 #128143 by oilypirate
Replied by oilypirate on topic 2low switch.
jonesyba420 wrote: Pretty sure I said that lol;)
Think hes concerned it could be different on a push button system.
Id pre wire a toggle switch, cut the cable we think it is then try it, if its not the right wire solder it back together no harm done.
:blush: just re read the posts my bad thanks guys i'll give this ago next week B)
  • ozzies
05 Nov 2014 19:00 #128604 by ozzies
Replied by ozzies on topic 2low switch.
Well I 've got round to the wiring . Remember I have a 2006 with electric switchAWD selection.
Took the handbrake cover off and exposed all the wires in the bundle . No wire colour matching manual select instructions.
3 blue wires in total
2 blue with black stripes
1 blue with red stripes and grey spots .
So not possible . Any ideas ? Anybody got wiring diagrams of newer model .
Ian
  • jonesyba420
06 Nov 2014 16:51 #128722 by jonesyba420
Replied by jonesyba420 on topic Re:2low switch.
Id think one of the wires will end up at the vacum controller.......believe this is by the battery under the bonnet.
If your soldering is upto scratch just pop it in 4wd pick a wire and cut it.......youll know when its the right one as only the hubs will unlock lol.
May be a last resort if you cant find a wiring diagram.
06 Nov 2014 18:04 #128728 by Busta
Replied by Busta on topic 2low switch.
Find the 4wd connector on the transfer box and see what colour wires go into it.
Or look at all the vacuum hub control stuff near the battery and see if any of the wires near the handbrake match the wires there. They'd be your best clues as to which it is!
It'll take a bit of detective work unless you can find someone else who has done it to a newer Jimny.
The following user(s) said Thank You: ozzies
Time to create page: 0.110 seconds
