2low switch.
- jonesyba420
30 Oct 2014 18:02 - 30 Oct 2014 18:05 #127952
by jonesyba420
Replied by jonesyba420 on topic 2low switch.
As far as im aware when you shift the lever to 4wd or 4wdL the transfer box engages the front prop and sends a signal to the vacumn controller which locks the hubs.
the switch basically interupt that signal, so with the switch "on" it all works as normal,when I put it in 4wd/L and flick the switch "off" the hubs dissengage.........the front prop is still connected in the t-box so everything up front still rotates the hubs are just unlocked.
I believe the new system is the same just with buttons so the wires COULD be the same but I dont know for certain.........only takes 2 minutes to take the handbrake surround off and have a look. Worst case scenario if you cut the wrong wire just solder it back together;)
Last edit: 30 Oct 2014 18:05 by jonesyba420.
- oilypirate
30 Oct 2014 19:04 #127960
by oilypirate
Replied by oilypirate on topic 2low switch.
can any one link me up to the/a how to guide for the wiring side of things?
31 Oct 2014 07:44 #128008
by Busta
Replied by Busta on topic 2low switch.
The wiring is simple. Find the appropriate wire (blue black with red spots). Cut the wire and extend each loose end to reach a toggle switch mounted wherever you want. The toggle switch simply acts as a break in the wire.
- jonesyba420
31 Oct 2014 13:03 #128021
by jonesyba420
Pretty sure I said that lol;)
Think hes concerned it could be different on a push button system.
Id pre wire a toggle switch, cut the cable we think it is then try it, if its not the right wire solder it back together no harm done.
- X8GGY
31 Oct 2014 14:10 #128022
Replied by X8GGY on topic 2low switch.
This is all very strange to me?, a Jimny newbie...
My transfer box works like this -
So when I shift to 4WD-Low, if I depress the clutch and then slide the transfer stick slightly left and forward, the 4x4 light goes out, the vacuum hubs disengage AND the front prop stops turning... 2WD-Low
Doesn't every Jimny do that?
Is it something to do with that Rockwatt fella from Scunthorpe
:whistle:
- gaz3359
31 Oct 2014 14:58 #128023
by gaz3359
show off !
Replied by gaz3359 on topic 2low switch.
Jimny-Dave wrote: This is all very strange to me?, a Jimny newbie...
Is it something to do with that Rockwatt fella from Scunthorpe:whistle:
show off !
Time to create page: 0.121 seconds
