2low switch.
  • jonesyba420
30 Oct 2014 11:44 #127932 by jonesyba420
Replied by jonesyba420 on topic Re:2low switch.
Not quite sure what you mean........do you mean why didnt suzuki produce the jimny with 2low?
30 Oct 2014 12:32 #127933 by Busta
Replied by Busta on topic 2low switch.
Yes that would be perfect and surely simpler too? Just 2 buttons! Only difference I can see is manufacturer would want the 4wd to always disconnect in the transfer case rather than use the hubs as a 2lo switch does.
  • Filfrasen
30 Oct 2014 13:43 #127942 by Filfrasen
Replied by Filfrasen on topic Re:2low switch.
Yes.
Only 2 buttons in the car from the faktory
1 hi-low button
1 2wd-4wd button
ex my bad Eng.
  • jonesyba420
30 Oct 2014 16:00 #127946 by jonesyba420
Im sure there is a valid reason otherwise they would have done it.
30 Oct 2014 17:13 #127948 by facade
Replied by facade on topic 2low switch.
Most likely they didn't want a load of people breaking rear half shafts trying to pull huge loads ;)
  • ozzies
30 Oct 2014 17:38 - 30 Oct 2014 17:39 #127951 by ozzies
Replied by ozzies on topic 2low switch.
So Jonesey please help me here .
The switch on your vehicle simply stops the air powered switches locking the front hubs - you select 4WD L with your manual lever , pop the switch and hey presto 2WD L ! Is that correct ?
With my electric 4WD L switch it should theoretically be the same . ie . same coloured wire for the front hub locks .
Does that sound plausible ? Somebody on the forum must have done this to a newer model by now .
Thanks,
Ian
Last edit: 30 Oct 2014 17:39 by ozzies. Reason: grammar
Time to create page: 0.112 seconds
