2low switch.
  • jonesyba420
29 Oct 2014 15:03 #127832 by jonesyba420
Replied by jonesyba420 on topic 2low switch.
Remove the handbrake surround and you will see wires going through the floor....
Remove the tape so you can see the individual wires, on mine 2002 hardtop its the blue wire with a black stripe and red dots you need to cut....
Join a separate wire (in my case the thick blue and brown) to each end of the cut wire and these to your on off switch....
Job done, sit back and admire your work, you now have a seperate switch you can use to operate the hubs.
  • ozzies
29 Oct 2014 18:00 #127854 by ozzies
Replied by ozzies on topic 2low switch.
Thanks a lot for posting. My Jimny is a 2006 with electric AWD and gear selection so I imagine this will be different don't you think ? Anybody know ???
  • jonesyba420
29 Oct 2014 19:18 #127862 by jonesyba420
Replied by jonesyba420 on topic Re:2low switch.
It may or may not be the same I have no idea.
  • Statey
29 Oct 2014 21:40 #127890 by Statey
Replied by Statey on topic Re:2low switch.
Epic cheers!
  • jonesyba420
29 Oct 2014 22:32 #127901 by jonesyba420
No worries.
  • Filfrasen
30 Oct 2014 11:33 #127931 by Filfrasen
Replied by Filfrasen on topic 2low switch.
Whay not from the beginning only 2 independent buttons ?
2wd-4wd
Hi-Low
