Jimny Diff breathers
- cal213
Also from australia
- cal213
- Bigjim91
mlines wrote: You can fit the axle ones with the axles in place.
The transfer box and gearbox have to be moved to drill. This makes it more of a task for these.
I have assumed that most people want to protect the axles first, so the kit can be installed in stages, with the transfer box and gearbox later. When you want to fit the other breathers you use some tee-pieces in the kit to cut in the extra sections.
I had an old "push-fit" hosepipe one originally on my car and it did not have the gearbox one fitted as it was too difficult on initial installation. I only fitted this when I moved the gearbox to change the clutch. I then foound it difficult to refit the gearbox with the push fitted garden hosepipe as it kept popping off the breather stub as I moved the gearbox into position, hence the moved to a threaded version.
The gearbox and transfer box breathers are higher up in the transmission tunnel where it is less likely to get wet and where there is air trapped in the tunnel anyway.
How deep can u go without gearbox and transfer case breathers?
Thanks
- ROCKOZ
Have you finished developing this kit yet?
I'd like one.
I have my own tap set though.
Many thanks
Ollie
- cal213
- topjimny
Bigjim91 wrote: How deep can u go without gearbox and transfer case breathers?
Thanks
Does anyone can explain to me the inner works of Martin's kit vs the one that just uses hoses ?
He did mention issues on the add-on kit (at least the gearbox) due to high oil working temperature. But i didn't understand why this hapeens too.
