Jimny Diff breathers
01 Jun 2013 13:16 #72380
Replied by mlines on topic Jimny Diff breathers
At the risk of the products appearing on a rival site.....
Here is a sneak preview of todays test.
As you may know, I was never a fan of the kits which used push-on hose pipe style solutions.
So here is my new kit fitted to a Jimny transfer box
And to an SJ Transfer box.
01 Jun 2013 18:40 #72399
by kirkynut
Replied by kirkynut on topic Jimny Diff breathers
Forgive my ignorance Martin but how do they connect if they are not push fit? How will the diff breathers fit, the same way?
- Keefe
01 Jun 2013 18:43 - 01 Jun 2013 18:45 #72400
by Keefe
Replied by Keefe on topic Jimny Diff breathers
Got them on mine.
Have used them on a mobile compressor connected to a set of train horns in a Carry van.
Working at 120psi, never had a problem with leaks or blowing off etc.
They were so easy to disconnect when required as well. Nice bit of kit.
So should work perfectly on any/all the boxes.
Last edit: 01 Jun 2013 18:45 by Keefe.
- Brian
01 Jun 2013 19:05 #72406
by Brian
Replied by Brian on topic Jimny Diff breathers
This is one of my next jobs.
I will buy a set off you
01 Jun 2013 19:12 #72409
The fittings are threaded so they are properly attached to the case rather than a piece of hose pipe and a clip over the stub of the old breather.
01 Jun 2013 20:11 #72412
by kirkynut
Sorry, I'm probably being dim but how does the threat screw onto say the diff breather??? It's just a tube coming off the axle, so how is it screwed on with a thread? I imagine it's obvious when you see the kit in your hand but I just can't think how it screws on from the piccie.
Sorry again for my dimness.
Time to create page: 0.150 seconds
