Jimny Diff breathers
19 Oct 2013 20:52 #87122 by mlines
Replied by mlines on topic Jimny Diff breathers
You can fit the axle ones with the axles in place.
The transfer box and gearbox have to be moved to drill. This makes it more of a task for these.
I have assumed that most people want to protect the axles first, so the kit can be installed in stages, with the transfer box and gearbox later. When you want to fit the other breathers you use some tee-pieces in the kit to cut in the extra sections.
I had an old "push-fit" hosepipe one originally on my car and it did not have the gearbox one fitted as it was too difficult on initial installation. I only fitted this when I moved the gearbox to change the clutch. I then foound it difficult to refit the gearbox with the push fitted garden hosepipe as it kept popping off the breather stub as I moved the gearbox into position, hence the moved to a threaded version.
The gearbox and transfer box breathers are higher up in the transmission tunnel where it is less likely to get wet and where there is air trapped in the tunnel anyway.
  • supergaz
19 Oct 2013 20:59 #87125 by supergaz
Replied by supergaz on topic Jimny Diff breathers
Martin, why not make things like taps an option?
  • Leathery1
19 Oct 2013 21:01 #87126 by Leathery1
Replied by Leathery1 on topic Jimny Diff breathers
Thanks Martin. very comprehensive explanation.
  • Keefe
19 Oct 2013 22:21 #87139 by Keefe
Replied by Keefe on topic Jimny Diff breathers
Blob of high temp thick grease on drill bit might help as well to catch some swarf.
Worked for me before now.
  • cal213
20 Oct 2013 02:39 #87143 by cal213
Replied by cal213 on topic Jimny Diff breathers
Pretty keen to get my hands on a set. Have a gearbox and transfer sitting waiting to be drilled ad axles will be out soon. Where will it terminate? Airbox, snorkel, engine bay? Cheers
  • Jimnyash
20 Oct 2013 08:48 #87157 by Jimnyash
Replied by Jimnyash on topic Jimny Diff breathers
For what little use I'll have for breathers, I think this kit is a bit above me, although it's a great kit.
Time to create page: 0.104 seconds
