Odd idea for winter
- Thank you received: 252
11 Nov 2012 14:46 - 11 Nov 2012 14:53 #52874
by j999pre
Grey pick up Jimny
Odd idea for winter was created by j999pre
Ok. I need my car for winter at very short notice. (seconds)
Therefore an iced windscreen is a big problem.
Is there an option of a second battery, a solar panel and a small 12v heater?
I don't want to be tethered to the mains our have anything to unplug.
Any thoughts anyone?
Cheers
Cheers
Grey pick up Jimny
Last edit: 11 Nov 2012 14:53 by j999pre.
- Smoggy
11 Nov 2012 14:50 #52875
by Smoggy
Replied by Smoggy on topic Odd idea for winter
Oh there's an idea
11 Nov 2012 14:57 #52876
by facade
Replied by facade on topic Odd idea for winter
Get one of those ice covers for the windscreen, just lift it off and drive away.
Solar panels don't work in the winter.
11 Nov 2012 15:34 - 11 Nov 2012 15:35 #52878
by j999pre
Wind turbine it is then
I have an insulated sheet I use but if it trains then freezes its a mare.
I have solar on the house and yes its not as good as in the summer it still works to some degree. The heater would only need to luck in at freezing temps then off again and the battery would get some charge on the way to work.
Grey pick up Jimny
Replied by j999pre on topic Odd idea for winter
facade wrote: Get one of those ice covers for the windscreen, just lift it off and drive away.
Grey pick up Jimny
Last edit: 11 Nov 2012 15:35 by j999pre.
- reaper
11 Nov 2012 20:52 #52936
by reaper
Replied by reaper on topic Odd idea for winter
On the old mini you could fit a heat exchanger on to the manifold to heat the washer jet water .
Maybe not in seconds but certainly helped clear the windows fast
- markyp2000
11 Nov 2012 21:02 - 11 Nov 2012 21:04 #52944
by markyp2000
Replied by markyp2000 on topic Odd idea for winter
you need some thing like this 271088836440 on ebay its to aid the engine warm up quicker and also gives you heat as it sits in the heater box
or get a garage to put it in if you have off road parking may be a car port
Last edit: 11 Nov 2012 21:04 by markyp2000.
Time to create page: 0.173 seconds
