33s Rubbing
  • reaper
20 Oct 2012 09:07 #50873 by reaper
Replied by reaper on topic 33s Rubbing
Sorry but all this seems a bit extream to me , what lift do you have on and what offset rims ?
When i had the 2" lift and 30" tyres all i had to cut was a little from the plastic arch to get full lock . . . . .your tyres are only 1.5" bigger from hub centre
  • panosd
20 Oct 2012 10:21 #50877 by panosd
Replied by panosd on topic 33s Rubbing
No its not that way.
the 30's are 74,3cm tall and 31's are 78.3cm tall. So we talk for 4cm bigger tire but also
20mm wider. The 30's are 245/75/15 and the 31's are 265/75/15.
From numbers to reality there is a big difference. I thought the same when i had to choose
between 31'' and 30'' and i went for 31'' because i said, eeehhh no big deal, is just 4cm.
But when i put them on and saw the trimming needed and some other mods, i understand
it.
  • Smoggy
20 Oct 2012 10:43 #50879 by Smoggy
Replied by Smoggy on topic 33s Rubbing
Not sure of the offset but the tyres are 285/75 on 16'' rims with agressive insa turbo tread, its true what Panosd says - in real life they are scary big :ohmy:
  • markyp2000
20 Oct 2012 13:10 #50884 by markyp2000
Replied by markyp2000 on topic 33s Rubbing
panosd wrote: No its not that way.
it.
if you have 30" tyres and then fit 31" tyres you only gain 0.5" of ground clearance and get closer to the arches by 0.5"
30's are 74,3cm tall and 31's are 78.3cm tall so thay are only 20mm closer to the rear of the arch and 20mm more ground clearance
  • reaper
20 Oct 2012 17:02 #50904 by reaper
it.
The 30" ones were also mt with large lugs and also had 32mm spacers fitted
You are not gaining 3 inch that is the total height you only gain half of that
  • Smoggy
20 Oct 2012 18:27 #50916 by Smoggy
All done
Time to create page: 0.215 seconds
