Ready to Underseal
  • goatboy
27 Jul 2012 08:00 #44979 by goatboy
Replied by goatboy on topic Re: Ready to Underseal
Quite a lot of rust there :(
Are both of your cars hardtop? (difficult to tell from the pictures...)
  • Keefe
27 Jul 2012 08:20 #44981 by Keefe
Replied by Keefe on topic Re: Ready to Underseal
Just remembered!
When you weld the floor, mask off/cover the windows. I didn't and ended up with tiny pock marks in the glass.
I'm not saying weld splatter did this, it could be from using an angle grinder for cutting the rust out to start with. All I know is, the glass wasn't like that before the repair.
  • adamatdraycott
27 Jul 2012 09:15 #44984 by adamatdraycott
Replied by adamatdraycott on topic Re: Ready to Underseal
The rear arches (and the majority of the under side of the body work) on Jimny’s have a textured finish to them, and it seems to hold up well against stone chips and rust. Don’t really see the point in undersealing these areas… I think I’m going to focus on the bare metal and the chassis. Might even use masking tape to keep my lines a bit neater ;) OCD much!
Mine is showing far less rust, and is mainly just surface scabs. Planning on using rust converter on the worst areas, and then waxoyl underseal
  • doncarlyon
27 Jul 2012 14:07 #44994 by doncarlyon
Replied by doncarlyon on topic Re: Ready to Underseal
This is the one thing i hated about my Jimny... the boot floor :(
  • markyp2000
27 Jul 2012 20:21 - 27 Jul 2012 20:21 #45001 by markyp2000
Replied by markyp2000 on topic Re: Ready to Underseal
goatboy wrote: Quite a lot of rust there :(
Are both of your cars hardtop? (difficult to tell from the pictures...)[/quote
if you look at both our avitar pic you will see
bear metal on the chassis where is that i looked under mine ant it fully undersealed with a thick layer apart from the boot floor
Last edit: 27 Jul 2012 20:21 by markyp2000.
  • adamatdraycott
30 Jul 2012 07:48 #45078 by adamatdraycott
Got both my rear arches undersealed this weekend… along with all the prep and rust treatment around the welds on the chassis. If you get underneath and look about 10inches in front of the rear wheels there is a body mount… which was quite heavily corroded on mine
As you said, in the main the arches are covered in a plastic like underseal except the boot floor, which I’ll get painted when I remove the back box and towbar
Time to create page: 0.168 seconds
