Some help and questions needed for my 06 jimny
- VAXXi
- Visitor
12 Jul 2012 21:39 #44049
by VAXXi
Replied by VAXXi on topic Re: Some help and questions needed for my 06 jimny
Glad to help :laugh: here's a list of compatible cabin filters:
Cabin filter (Suzuki 95860-81A10)
Mann CU 2129 (206x180x20.5 mm)
Mahle LA 95 (06418537, 206x180x20.5 mm)
Knecht 06418529 (206x180x20.5 mm)
VIC AC-931E
UFI 53.127.00
Airmatic IF0174
Frigair 13145321
Meat & Doria 17329
Bosch 1987432156
Mecafilter JLR7209
Corteco CC1365 (activated carbon) or CP1365 (simple)
I try to keep a list of compatible parts on my blog, here: vaxxi.net/log/suzuki-jimny-parts/
VIC AC-931E
UFI 53.127.00
Airmatic IF0174
Frigair 13145321
Meat & Doria 17329
Bosch 1987432156
Mecafilter JLR7209
- adamatdraycott
- Visitor
13 Jul 2012 12:54 #44087
by adamatdraycott
Replied by adamatdraycott on topic Re: Some help and questions needed for my 06 jimny
Learnt something i have wondered about for 2years!
A neighbour has a pine tree with needles that drop all over my Jimny... once these get into the blowers the cabin gradually fills with needles that get fired out whenever i put my blowers on!
Just called 2 dealers... one argued that Jimny's don't have pollen/cabin filters... the other gave me a price of £30+VAT
- AJ
- Visitor
22 Jul 2012 06:46 #44705
by AJ
Replied by AJ on topic Re: Some help and questions needed for my 06 jimny
Do go ahead and stuff one of the filters in... you do not really wanna know what you might be sniffing all these while! hahaha..
- Kitsun
- Visitor
27 Jul 2012 15:18 #44996
by Kitsun
Replied by Kitsun on topic Rain water leaking into jimny footwell - solved
Guys, after the severe typhoon just hit us in Hong Kong, found the passenger footwell flooded with about an inch of water. That's the only area where rain leaked in. Removed as much water as possible but too lazy to remove the carpet to dry underneath. Cat Crystals (silica gel kitty litter) to the rescue. Put the Cat Crystals into an old pillow case and lay the lot on the damp carpet. Bone dry carpet in 24 hours.
Sorted the leakage problem. Apparently near the front cabin air intake underneath the black plastic trim below the windscreen there are drain holes driver side and passenger side. The drain holes are blocked by plant debris over time and the water level builds up and overflows into the cabin via the cabin freshair intake.
Using a garden hose on high pressure a cleared the drain holes and no more rain leakage into the cabin. Getting access to clear the drain holes requires removing the black plastic trim underneath the windscreen.
Time to create page: 0.158 seconds
