Some help and questions needed for my 06 jimny
- AJ
24 May 2012 09:09 #41071
by AJ
Some help and questions needed for my 06 jimny was created by AJ
Hi guys, i am new here and i'm here to stay
need some help though..
i found my windscreen leaking and replace it, dried the whole interior. And went out last night and drove past some little tiny puddle of water. I dunno if that water is the culprit but my car interior carpet is all wet again.. All wet = driver, passenger and the back.. I dunno where the leak is from and the last time after fitted the new windscreen seal..the workshop tested with hose spraying water on windscreen side window roof etc and all seems good until today i touch the carpet and its wet.. Any kind soul who might have experience can help me out with ur past experience? I dun wan the car to rust and the smell to linger.. And i havent gotten the chance to mod and go off road! :ohmy:
- AJ
24 May 2012 09:16 #41073
by AJ
Replied by AJ on topic Re: Some help and questions needed for my 06 jimny
Another question, how do most of you clean your car exterior and interior after playing with mud etc..? Are we able to power wash undercarriage of the car with all the metal parts there? I havent see a thread with cleaning method..bet the engine bay gets mud and sand and its not gonna be easy to clean up.
- edinburghmotorco
24 May 2012 09:36 #41074
by edinburghmotorco
Replied by edinburghmotorco on topic Re: Some help and questions needed for my 06 jimny
could be a leak from the heater matrix, if water runs into the air intake at the windscreen and a pipe has worked loose somewhere then water will pour into your footwell
Thats what happens to Mercedes all the time and i have seen a fair share of heater issues with Jimny's so it might be similar.
- AJ
24 May 2012 14:10 #41088
by AJ
Thanks for the fast response! Assuming thats the cause, how can i go about looking for the leak and what should i do to fix it?
- edinburghmotorco
24 May 2012 14:46 #41089
by edinburghmotorco
you can try a hose test direct at the air intake below the windscreen, if you see water coming into either footwell then its the hose connection to your heater system under the dash. The main heater box is under your left hand side dash normally.
Its a bit of a basta*rd to get to for a repair though. Say 'heater matrix' to our workshop foreman and he goes white!
- adamatdraycott
25 May 2012 06:28 #41122
by adamatdraycott
Replied by adamatdraycott on topic Re: Some help and questions needed for my 06 jimny
I've tried removing that black plastic trim from infront of the windscreen... gave up after taking everything off and it was still stuck solid!
Time to create page: 0.171 seconds
