battery again
24 Jan 2012 18:02 #31754 by kirkynut
Replied by kirkynut on topic Re: battery again
Would this be suitable?
www.x-eng.co.uk/X-Charge.asp
The following user(s) said Thank You: SUGAR DELTA
  • zerez
24 Jan 2012 18:19 #31760 by zerez
Replied by zerez on topic Re: battery again
What you need is electric system similar to boat system.
The two batteries are not connected but have a split charging system.
One of the batteries is the main battery, used to start the engine and the second battery is for all other consumers.
This way even if you run out of battery you will be able to start.
  • SUGAR DELTA
24 Jan 2012 18:35 - 24 Jan 2012 18:36 #31770 by SUGAR DELTA
Replied by SUGAR DELTA on topic Re: battery again
Cheers all,I like the look of this and at £40 it will do :)
Last edit: 24 Jan 2012 18:36 by SUGAR DELTA.
  • Jande
08 Feb 2012 13:55 #33018 by Jande
Replied by Jande on topic Re: battery again
my dual battery system.
i have make trunk new metal box two battery, i jus cut hole and welding new bigger box.
i have 120amp alternator. battery is 2x72ah and 610amp .
[IMG
[IMG
  • Smoggy
08 Feb 2012 18:45 #33050 by Smoggy
Replied by Smoggy on topic Re: battery again
HiJande where did you get 120amp alternator for your jimny.
  • Jande
08 Feb 2012 22:03 #33098 by Jande
yes i have 120apm alternator, but i have 1.9tdi vw engine;)
Time to create page: 0.249 seconds
