battery again
- SUGAR DELTA
22 Jan 2012 21:31 #31610
by SUGAR DELTA
battery again was created by SUGAR DELTA
I think i'm gonna get a split charge system and put a 110Ah leasure battery in the boot.
Question,would the standard alternator be good enough for this task ?
Cheers folks
Cheers folks
- supergaz
22 Jan 2012 21:38 #31614
by supergaz
Replied by supergaz on topic Re: battery again
Yup, just use a split charge system of lesser rating. 60Ah max.
- TomDK
23 Jan 2012 09:36 #31625
by TomDK
What's the reason you want a split charge system ?
If it's just for winching there's no real reason for it. Just parallel connect the batteries.
Replied by TomDK on topic Re: battery again
SUGAR DELTA wrote: I think i'm gonna get a split charge system and put a 110Ah leasure battery in the boot.
Cheers folks![]()
- 247sniper
23 Jan 2012 11:14 #31630
by 247sniper
Replied by 247sniper on topic Re: battery again
Connect the batteries in SERIES.
Steve.
Steve.
- reaper
23 Jan 2012 11:41 #31631
by reaper
Replied by reaper on topic Re: battery again
dont direct connect batteries all this does is strain the alternator . split charger is the way to and for about a fiver will save you an expensive alternator
- TomDK
23 Jan 2012 12:13 #31633
by TomDK
And go for 24V ?
All the challengetrucks I've seen have no need for fancy split charger. Two batteries in parallel connection works fine.
247sniper wrote: Connect the batteries in SERIES.
Steve.
And go for 24V ?
Time to create page: 0.182 seconds
