battery again
  • 247sniper
23 Jan 2012 12:49 #31634 by 247sniper
Replied by 247sniper on topic Re: battery again
Can you explain how two batteries can be wired in parallel ??
Steve .
  • reaper
23 Jan 2012 13:00 #31636 by reaper
Replied by reaper on topic Re: battery again
2 in series =24v will blow car elecrics
2 in parralel = 2 x ah that will strain and posibly blow the alternator
ad to that the need for large cable running to the boot and its all a bit point less
get a cheep spliy charger it uses nice small cable that is eazily run . and it auto detects wbdn main batter if full and switches charge to secondary , no chancs of ever running main battery flat
  • TomDK
23 Jan 2012 13:13 #31637 by TomDK
Replied by TomDK on topic Re: battery again
247sniper wrote: Can you explain how two batteries can be wired in parallel ??
Steve .
It's not that hard.
+ > + (positive to positive)
- > - (Negative to negative)
  • reaper
23 Jan 2012 15:07 #31644 by reaper
the problem you have if not using a split charger is your 60A altanator trying to charge a 110A+60A battery
170A is to much for it
add to that the stronger of the 2 batteries will always try to back feed so it will not get to its full capacity and may even damage the smaller one by overcharging it
  • SUGAR DELTA
23 Jan 2012 18:37 #31663 by SUGAR DELTA
Replied by SUGAR DELTA on topic Re: battery again
supergaz wrote: Yup, just use a split charge system of lesser rating. 60Ah max.
60Ah split charging system,ok why is this please?
If I want to charge a 110Ah don't I need one that's rated for that ?
Cheers =)
  • SUGAR DELTA
23 Jan 2012 18:39 - 23 Jan 2012 18:43 #31664 by SUGAR DELTA
TomDK wrote:
SUGAR DELTA wrote: I think i'm gonna get a split charge system and put a 110Ah leasure battery in the boot.
Question,would the standard alternator be good enough for this task ?
Cheers folks :)
What's the reason you want a split charge system ?
If it's just for winching there's no real reason for it. Just parallel connect the batteries.
The reason is I use amateur radio equipment and quite a powerful linear amp.
The radio draws around 10 amps and the linear around 45 ish..
Last edit: 23 Jan 2012 18:43 by SUGAR DELTA.
Time to create page: 0.210 seconds
