battery again
  • SUGAR DELTA
23 Jan 2012 18:42 #31667 by SUGAR DELTA
Replied by SUGAR DELTA on topic Re: battery again
No eBay APP ID and/or Cert ID defined in Kunena configurationI was looking at this,would it be overkill?
  • Smoggy
23 Jan 2012 19:30 #31676 by Smoggy
Replied by Smoggy on topic Re: battery again
I am an electrician and although vehicle electrics differ, the principles of current flow vs resistance vs voltage dont change.
Reapers philosophy on this subject is sound.
  • supergaz
23 Jan 2012 19:58 #31681 by supergaz
Replied by supergaz on topic Re: battery again
SUGAR DELTA wrote:
supergaz wrote: Yup, just use a split charge system of lesser rating. 60Ah max.
60Ah split charging system,ok why is this please?
If I want to charge a 110Ah don't I need one that's rated for that ?
Cheers =)
This is because your jimny alternator only gives out 60Ah, you only need to trickle charge an auxilary battery.
I am a qualified electrical and electronic engineer and fully agree with Reaper.
  • jimny5
23 Jan 2012 20:50 #31690 by jimny5
Replied by jimny5 on topic Re: battery again
I ran two batterys without a split charge and found when winching the alternator struggle to give full power and one battery would drain the other without fully charging both them up.
Go with reapers advise, its nice and simple could even fit some gauges to double check readings.
24 Jan 2012 14:46 - 24 Jan 2012 14:49 #31728 by Johnniehec
Replied by Johnniehec on topic Re: battery again
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
SUGAR DELTA wrote: I was looking at this,would it be overkill?
This is not an automatic split charge system it's only a manual relay and a very expensive one at that, you can get the same relay here www.vehicle-wiring-products.eu/VWP-onlin...lays/relays.php#high
for £16 which means you're paying £54 for a couple of fuse holders, a bit of wire and a few cable ties.
I think you're after one of these, can someone confirm it's "big" enough?
John.
Last edit: 24 Jan 2012 14:49 by Johnniehec.
The following user(s) said Thank You: SUGAR DELTA
  • SUGAR DELTA
24 Jan 2012 16:56 #31745 by SUGAR DELTA
John.
Cheers bud,I aint bought anything yet .
I echo can anyone tell me if 30amp is big enough to charge a 110ah leasure battery from the alternator?
