4x4 not engaging
  • doncarlyon
  • Visitor
  • Visitor
10 Jan 2012 13:24 #30467 by doncarlyon
Replied by doncarlyon on topic Re: 4x4 not engaging
Just lock the front hubs permanently... simples!
  • Rswo
  • Visitor
  • Visitor
10 Jan 2012 13:30 #30469 by Rswo
Replied by Rswo on topic Re: 4x4 not engaging
Might be a silly question, however:
what problems would I be the cons if I left it in 4 wheel drive when it did go in? as I said earlier it does go in 1/10ish times
  • Rswo
  • Visitor
  • Visitor
10 Jan 2012 13:32 - 10 Jan 2012 13:34 #30471 by Rswo
Doncarlyon, ur answered my questions whilst I was typing. However is there any cons to this ie wear/tear, fuel consumption, steering etc etc
Last edit: 10 Jan 2012 13:34 by Rswo.
  • doncarlyon
  • Visitor
  • Visitor
10 Jan 2012 13:32 #30472 by doncarlyon
You dont want to be driving on the road in the dry in 4wd. You will end up breaking it :(
Lock the front hubs manually, then block the vacuum pipes so that the vacuum doesnt get to the hubs but no water can get in. Then it will work no worries. But you will get the 4wd light flashing at you when you select 4H and 4L.
  • doncarlyon
  • Visitor
  • Visitor
10 Jan 2012 13:34 #30473 by doncarlyon
Mine were permanently locked when i bought the car. I replaced them with some Aisin manual hubs hoping that i would get a bit more power in 2wd and better MPG, in reality it made no difference.
They only gain i see is that i can use low range in 2wd. (surprising how well you can get around in 2L :) )
  • Rswo
  • Visitor
  • Visitor
10 Jan 2012 13:38 #30474 by Rswo
doncarlyon wrote: You dont want to be driving on the road in the dry in 4wd. You will end up breaking it :(
How would you lock it manually? I prosume you would need to buy the kit
Time to create page: 0.204 seconds
