4x4 not engaging
  • Rswo
  • Visitor
  • Visitor
09 Jan 2012 21:29 - 09 Jan 2012 21:36 #30419 by Rswo
4x4 not engaging was created by Rswo
Having trouble with the vacuum system on my jimny. The light goes on when I engage however it is not engaging. Were do I start? I can feel a vacuum from the Vacuum check valve and then from there I'm lost. Not the best at DIY! 1/10 times it does engage. What else can I test?
Lastly I heard a bit of talk about manual hubs, is this a good idea?
All the best,
Rswo
Last edit: 09 Jan 2012 21:36 by Rswo.
  • vitara_mad
  • Visitor
  • Visitor
10 Jan 2012 08:02 #30435 by vitara_mad
Replied by vitara_mad on topic Re: 4x4 not engaging
yes the best fix is to fit manual hubs
  • 247sniper
  • Visitor
  • Visitor
10 Jan 2012 09:05 #30443 by 247sniper
Replied by 247sniper on topic Re: 4x4 not engaging
Check all the vac pipes and metal vac pipes. You most likely have a split rotten/corroded vac pipe.
Let us know what you find mate.
Steve.
  • goatboy
  • Visitor
  • Visitor
10 Jan 2012 11:04 - 10 Jan 2012 11:58 #30458 by goatboy
Replied by goatboy on topic Re: 4x4 not engaging
I had exactly this problem, I took the hubs off and mine were really thick with grease which seemed to be blocking the vacuum. I cleaned it up and it helped and got up to about 3/10 sucess rate.
I started looking at the hoses and a few people have had mixed sucess with changing them out.
So I started looking, changed a few pipes with limited sucess and at this point I then gave up and fitted manual hubs....
bigjimny.com/index.php?option=com_kunena...6&id=26152&Itemid=75
Edit to add: I did seem to have a good vacuum at the hubs but it still didn't work. maybe it wasn't good enough...
Last edit: 10 Jan 2012 11:58 by goatboy.
  • jo king
  • Visitor
  • Visitor
10 Jan 2012 11:17 #30459 by jo king
Replied by jo king on topic Re: 4x4 not engaging
All you need is about 4 meters of 4mm polyurethane and 2x 4mm push fit tees
the whole job takes me 20 mins but I have done it on three different jimnys with 100 percent success. the tees part number 3104 04 00 you will need two and you can order from
parker 01926317878 . this is the most cost affective way to ensure you have a good reliable set up. with the pipes out of harms way and you dont need to get out of the jimny in the snow and bring all the snow into your jimny. the whole original pipe system can be taken off and chucked...
DO all this at your own risk I will not be held responsble for any infomation I have shared..
  • Rswo
  • Visitor
  • Visitor
10 Jan 2012 13:09 #30464 by Rswo
Replied by Rswo on topic Re: 4x4 not engaging
jo king wrote: All you need is about 4 meters of 4mm polyurethane and 2x 4mm push fit tees
Are you then going from engine straight to hubs? Or following through the valve and tank etc?
Rswo
