4x4 not engaging
  • doncarlyon
  • Visitor
  • Visitor
10 Jan 2012 14:00 - 10 Jan 2012 14:03 #30475 by doncarlyon
Replied by doncarlyon on topic Re: 4x4 not engaging
No need to buy anything!
Just take the hubs off (torx bolts) the centre part is spring loaded, put them into the locked position, bolt them back up and pull the pipes off the hub.
Ideally you want to block off where the pipes were connected to the hub to stop any muddy water getting in.
Look here - www.bigjimny.com/index.php?option=com_co...drivechain&Itemid=37
Last edit: 10 Jan 2012 14:03 by doncarlyon.
  • Rswo
  • Visitor
  • Visitor
10 Jan 2012 14:33 #30478 by Rswo
Replied by Rswo on topic Re: 4x4 not engaging
doncarlyon wrote: No need to buy anything!
Thanks, therefore when this is done its in 4 wheel drive therefore u would then need to reverse this action ever time you then go onto the open road, is that right?
As a said not the brightest spanner in the box when it comes to DIY
  • doncarlyon
  • Visitor
  • Visitor
10 Jan 2012 14:51 #30480 by doncarlyon
No, if you manually lock the front hubs but select 2wd it will still just be 2wd.
Normally when you select 4wd the vacuum system is triggered to activate the front hubs, this wont happen anymore as they are already selected / activated.
The difference is that in 2wd, as the front wheels are being pushed along they are turning the drive shafts and the diff and the front prop which will add a small amount of drag, wear&tear, etc. but I cant see it being an issue. And the drag / mpg difference isnt even noticeable.
  • Rswo
  • Visitor
  • Visitor
10 Jan 2012 15:24 #30486 by Rswo
Ok thanks I will add this to the options
  • Rswo
  • Visitor
  • Visitor
10 Jan 2012 15:39 #30489 by Rswo
Well I've got three option:
Replace all the vacuum piping and hope that resolves the issue
Manually lock the front
Or
Fit a set of manual locking hubs From Bits4Vits
Looking at this and other forums There seems to be a majority going for The third option.
What does everyone think, need to get it sorted Asap
  • goatboy
  • Visitor
  • Visitor
10 Jan 2012 15:44 #30491 by goatboy
Replied by goatboy on topic Re: 4x4 not engaging
Its dead easy to fit manual hubs and the ones from bits4vits are great value and at least you know they work.
For me I felt I could have spent £30+ on replacing the vacuum piping and it still not work, so biting the bullet and spending the money on the manual hubs I know will work was the best option for me.
All depends on if you have a spare £160 floating around. If you do then go for it!
